It is currently Sun Jul 20, 2025 4:10 pm
 Post subject: My engine on the dyno
PostPosted: Thu Jul 05, 2007 11:25 pm
http://www.youtube.com/watch?v=msDSbcsPrhc
:D
PostPosted: Thu Jul 05, 2007 11:28 pm
Forum Graffiti
:shock:
:D
this i had been waiting to see...
nice work! :D
PostPosted: Thu Jul 05, 2007 11:33 pm
sounds awesome!!!
what did it pull on the dyno?
PostPosted: Thu Jul 05, 2007 11:35 pm
Figures are in the little description.
136hp - 114ft/lbs
PostPosted: Thu Jul 05, 2007 11:45 pm
thhats just sexual.
ur motor is fantastic
Graham Russell is a god. thats a fact.
Good on u william. ur car will be awesome
**why didnt i have the foresight to film my motors aye ? **
PostPosted: Fri Jul 06, 2007 9:53 am
Yeah I just can't wait to get it into a body and have a go with it.
And Graham is a master.
PostPosted: Fri Jul 06, 2007 11:09 am
Awesom willy what did you do to it :?: give us the spec
PostPosted: Fri Jul 06, 2007 11:23 am
12G940 cylinder head
Converted to 11-stud
Mk 2 Cooper S valves
Hardened valve seats
Double valve springs
Fully flowed and developed
Swiftune 1.5:1 Roller rockers
Isky cam followers
A+ lifters
GR custom camshaft - he won't tell me the specs but it has 466 thou lift @ valves!
A+ block bored .094" (94 thou)
Hypertec 94 thou pistons
Hastings piston rings
AEG521 Cooper S conrods - lightened and balanced
A+ crankshaft offset ground (Stroked - 84mm) , wedged, lightened and balanced
Lightened single-piece flywheel
Cooper S backing plate - lightened
Borg & Beck orange dot friction plate
AP Racing riveted clutch pressure plate
Central oil pickup
Full synchro A+ rod change gearbox
Straight cut 1:1 drop gears
Cooper S 3.44:1 ratio differential
Tran-X diff centre
Rollmaster adjustable double row timing chain
Full ARP bolt, stud and nut kit (rods & head)
45DCOE Weber on GR 5.5" manifold
And probably a few other bits. So the cc will be a touch over 1410cc, and compression a bit over 11:1.
PostPosted: Fri Jul 06, 2007 11:27 am
Location: Woodside, Hahndorf and Mount Barker South Australia
bloody ell I want one................dear Santa, I have been a very good boy this year and I eat all my vegies and clean up after myself.......................lol
people say keep ya friends close and you enemies closer BAH I say keep your friends close and your enemies at maximum effective range.
PostPosted: Fri Jul 06, 2007 11:43 am
slober slober sounds the business :D
PostPosted: Fri Jul 06, 2007 11:47 am
:D i agree with Czerial...not quite to the point of his youtube comment tho :lol:
PostPosted: Fri Jul 06, 2007 11:54 am
you should've kept little willy...
that would've been a super sleeper.. :)
PostPosted: Fri Jul 06, 2007 12:29 pm
I'm Ernie , Where's Bert ?
SHITE!! thats awesome!
00' Forester GT
PostPosted: Tue Jan 20, 2009 2:17 pm
18 months later and it's sitting in the shed waiting for its owner to get another startup... in the new body that is back from the paint shop! Soon... soon.
PS This is the engine that I got an ET of 14.8 @ WSID.
Definitely need to look at getting an LSD for it - wheelspin in 3rd wasn't enjoyable.
PostPosted: Tue Jan 20, 2009 3:00 pm
Whens the quaife coming?
