It is currently Mon Jul 28, 2025 9:11 am
PostPosted: Sat Jun 25, 2016 7:04 pm
Changing back to a generator on my moke and am unsure if the polarity of the generator has been changed to negative earth.
How to ensure it is negative earth if someone who owned the generator before me didn't do it?
Thanks
PostPosted: Sat Jun 25, 2016 7:07 pm
Just re-do it to be safe
PostPosted: Sat Jun 25, 2016 7:11 pm
:?: :?: Use the Generator casing to hide something like a Motorcycle Alternator :idea:
PostPosted: Sat Jun 25, 2016 7:15 pm
if its a std issue Lucas mini generator
then all you need to do is hook up the battery (Neg earth or pos earth) depending on what you want
make sure your coil is wired to suit also
then turn the ign key on & it will automatically Pole itself
start the car & test output charge with multi-meter to confirm all is well
PostPosted: Sat Jun 25, 2016 8:04 pm
Thanks Matt
So does it all by itself. All I wanted to know
Thankyou
PostPosted: Sat Jun 25, 2016 8:45 pm
....... and change the wires around on the heater fan too, otherwise it will try to suck air out of the cabin :-)
Curly
PostPosted: Sat Jun 25, 2016 9:11 pm
It has no heater, I was originally running a generator and it kicked it while on holidays so had get an alternator wired up, and that has recently kicked it in, so going back to generator.
PostPosted: Sat Jun 25, 2016 11:26 pm
Don't forget to oil it. :P
PostPosted: Sun Jun 26, 2016 12:19 am
Hahaha.. someone remembered.
PostPosted: Mon Jun 27, 2016 12:47 pm
Bubbacluby wrote:
Thanks Matt
Thankyou
field terminal is "flashed" to earth after reversing the battery terminals using a wire from the +ve terminal is the correct method.
....you just lost him his insurance bonus!
997
PostPosted: Mon Jun 27, 2016 5:19 pm
I wouldn't take anything for granted. you run the risk of ruining the Voltage regulator or cutout points. It takes two seconds to just ark between the F wire and the B+ on regulator box and job is done.
"Let us remove your "SHORTS"
Users browsing this forum: winabbey and 63 guests
