https://ausmini.com/forums/
Will these fit with 7.5' discs?
https://ausmini.com/forums/viewtopic.php?f=2&t=32697
Author:  EST-071 [ Sun Jun 10, 2007 4:07 pm ]
Post subject:  Will these fit with 7.5' discs?
Hi all, will these wheels fit with 7.5' discs and innocenti black plasic flares?
I have heard that they may rub on the caliper but I that should be easy to fix with a grinder.
Cheers Pete
http://cgi.ebay.co.uk/mini-cooper-rever ... dZViewItem
Image[/url]
Author:  sports850 [ Sun Jun 10, 2007 4:15 pm ]
If they are the original steel rims (they look like it) and you're using standard mini 7.5" discs (no fancy calipers) then they'll fit over the brakes without any drama's . I don't know how wide the Innocenti flares are to know whether they'll fit under the flares or not though . I'd suggest looking in Australia for some before buying them overseas as the postage/freight could be scary ...
Author:  EST-071 [ Sun Jun 10, 2007 4:25 pm ]
Thanks sports850, I am currently running mini offset contessas with the flares and they are just legal.
Cheers Pete
Author:  sports850 [ Sun Jun 10, 2007 4:36 pm ]
I'd say these would stick a fair way outside then if the mini offset are just under the flares . These normally had an inch or so extra on each side when compared to standard cooper s rims .
Author:  EST-071 [ Sun Jun 10, 2007 4:40 pm ]
Well I guess I will not be getting wheels like that then.
Cheers Pete
Author:  sports850 [ Sun Jun 10, 2007 4:42 pm ]
Standard cooper s rims should be alright though , just not the reverse ones , keep an eye out , you never know what turns up .
Author:  drmini in aust [ Sun Jun 10, 2007 7:41 pm ]
My mate has reverse S wheels on his S and they are legal with the stock S flares. Which are about as wide as Inno flares.
But those wheels in your pic look wider than 4.5".....
Author:  Asphalt [ Sun Jun 10, 2007 8:57 pm ]
Even the 3.5" standart-wheels fit over 7.5" S-discbrake.
There`re only some early types which doesn`t.
(But dunno if australian wheels are different...?)
But even if the wheels rub on the caliper... I would do everything - but not grind it :shock:
The inno-flares are as far as i remeber as wide as the standart-ones (plastik-type) are.
If they do not fit, they will if you use a negative-kit ;)
