It is currently Sun Jul 27, 2025 10:52 pm
 Post subject: daily routines?
PostPosted: Tue May 29, 2007 11:07 pm
I'm Ernie , Where's Bert ?
just curious wat the daily routines are for everyones minis....atm ive just been checking the oil and coolant...well the water and rust in there :P anything else i should be checking as well..i noticed one of my resoviours on the left side of the engine bay is a little low...i think its the clutch..but dunno..
PostPosted: Tue May 29, 2007 11:15 pm
B4 i go for a drive, i always check oil/water/brake fluid. And just have a general look for any obvious problems.
I do the same in my Crappadore usually once a week.
PostPosted: Tue May 29, 2007 11:16 pm
are some coolants better than others?
Talk is Cheap because Supply Exceeds Demand
mattsmadmini wrote:
you've got awesome norbles
PostPosted: Tue May 29, 2007 11:24 pm
dont need coolant in most minis just water will do i only run a additive in mine to stop rust :wink:
PostPosted: Tue May 29, 2007 11:32 pm
once u know how much oil ur car uses then u will only need to check it once a week or so if ur goin to be usin it as a daily if ur car runs hotter then normal in the same weather theres a hint u need to check ur water :wink:
PostPosted: Tue May 29, 2007 11:34 pm
Yes.
From experience,I can only highly recommend Redline Water Wetter :D
PostPosted: Tue May 29, 2007 11:37 pm
I sweep the rust that has precipitated from the underside onto the floor into a dustpan.
PostPosted: Tue May 29, 2007 11:48 pm
yeah well there is two bottles on the left side of the car.....um what exactly are they...im guessing clutch and brake fluids???? just curious..cause its a fair bit different to my bm's engine :lol:
PostPosted: Tue May 29, 2007 11:54 pm
On my mini, one is clutch, and the other is break. and it shuld say on it what they are, or have a little picture or something.
PostPosted: Wed May 30, 2007 7:59 am
They both use the same stuff, so just make sure they are both full. Easy.
No more Minis!......For now.
PostPosted: Wed May 30, 2007 8:35 am
On all cars - every car ever made - one should say clutch and the other should say brake. Its the only way we are ever going to break the break for brake cycle.
PostPosted: Wed May 30, 2007 9:24 am
Hanra wrote:
B4 i go for a drive, i always check oil/water/brake fluid. And just have a general look for any obvious problems. Then give it a quick respray.
:P
PostPosted: Wed May 30, 2007 9:30 am
May daily routine is to check the oil and water and then give my credit card number out for the replacement parts that expired during the night.
PostPosted: Wed May 30, 2007 11:34 am
:lol: :lol: :lol:
i check to see howmuch of the floor pan is still attached to the car, then i check around the car to see if anybodys knicked anything off it, or how many new trolley dings its got after being at the shops.
check oil and water, brake / clutch levels, check how much tread i have left on my tires, check if you can visibly see anything unroadworthey.
PostPosted: Wed May 30, 2007 1:44 pm
when i get in the car.. i check that the mini is still resting there and hasn't rusted into the earth.. :)
