https://ausmini.com/forums/
Thermostat
https://ausmini.com/forums/viewtopic.php?f=2&t=32616
Author:  3DJ [ Fri Jun 08, 2007 8:54 am ]
Post subject:  Thermostat
Hey all, just a quick one...
Thermostat, how important is it? Are there risks if its not in? What is the best type to use and are they readily avaliable (supercraps etc)?
Author:  sports850 [ Fri Jun 08, 2007 9:01 am ]
If the thermostat isn't in and you don't use a blanking sleeve then the water is likely to go too fast to have time to cool in the radiator . Also the motor will be slower to warm up without a thermostat . They are available pretty much anywhere (supercrap etc) , not sure on best temp to get but I normally drill two 1/4" holes into the flat bit of them to allow water to circulate better than just the bypass hose while the thermostat is closed .
Author:  drmini in aust [ Fri Jun 08, 2007 9:07 am ]
there are 3 different temp ones- 74C, 82C, 88C. I use the 82. A 74 is too cold for winter use and I reckon the 88 is too hot for Oz.
Cheaper to buy em from Karcraft etc lately, rather than Superdear... :lol:
Author:  3DJ [ Fri Jun 08, 2007 9:38 am ]
Thanks for the replies, are they a specific size for the mini or is it a generic item?
Author:  drmini in aust [ Fri Jun 08, 2007 11:09 am ]
It's a common size, eg a Chevy 350 smallblock takes the same one...
