Tapping question https://ausmini.com/forums/viewtopic.php?f=2&t=32536 |
Author: | mini-dunger [ Tue Jun 05, 2007 9:49 pm ] |
Post subject: | Tapping question |
Hi guys I pulled a thread while tightening the drive hub to my disc today. I am going to pull the hub off and retap the thread. Does anyone have any hints or tips?. Whould I be better off to drill it out first and start fresh or just tapp it how it is?. also would I be better off using a UNC tap as its a bit courser? or should I use a UNF? or lastly there is enough room inside the disc hub to fit a bolt, should I just do that? Oh its cast iron. Thanks everyone |
Author: | Curly [ Wed Jun 06, 2007 6:50 am ] |
I'd be drilling out the old thread and replacing it with a helicoil of the original size. |
Author: | drmini in aust [ Wed Jun 06, 2007 6:56 am ] |
I'd be getting a new pair of rotors, they are pretty cheap... helicoiling an old one is not worth it by the time you buy the kit to do it. ![]() |
Author: | Clubbie74 [ Wed Jun 06, 2007 5:49 pm ] |
One of your local engineering places might weld and tap it for you with the right inducement - cold cans. |
Author: | drmini in aust [ Wed Jun 06, 2007 7:21 pm ] |
Clubbie74 wrote: One of your local engineering places might weld and tap it for you with the right inducement - cold cans.
1. You don't weld brake or suspension parts to repair them. illegal. ![]() 2. It's cast iron, welding a stressed iron component like a brake rotor is a recipe for disaster. They crack easily enough if you're unlucky, even unwelded.. ![]() <edit> trust me, I'm a welding engineer... ![]() |
Author: | mason [ Wed Jun 06, 2007 7:36 pm ] |
I ended up doing the same thing the other day on my car.I drilled and tapped and fitted a helicoil seems to be ok have done a track day with it like that but i am still keeping an eye on it |
