psi https://ausmini.com/forums/viewtopic.php?f=2&t=32486 |
Author: | minidrifter [ Mon Jun 04, 2007 8:02 pm ] |
Post subject: | psi |
just wondering what psi you guys were running as i think my front tyres are a little low |
Author: | Maxi23 [ Mon Jun 04, 2007 8:05 pm ] |
I always ran about 32 psi all around. |
Author: | VicMini13 [ Mon Jun 04, 2007 10:07 pm ] |
I usually start at 32 front and 30 rear then adjust from there. My Rover Cooper on 13x7's with Dunlop 195x45 is happy at that, but the wifes almost identical Rover on 13x7's with Goodyear 175x50 is better at 34 front and 32 rear. I run the Mini K van on standard 10's at 28 all round (a little higher when loaded). |
Author: | tinymorris1969 [ Mon Jun 04, 2007 10:17 pm ] |
ive found 32 abit bumpy so i use 30 up from and 28 at the back car grips well and handles great |
Author: | Spaceboy [ Mon Jun 04, 2007 11:59 pm ] |
http://www.ausmini.com/forums/viewtopic ... e+pressure http://www.ausmini.com/forums/viewtopic ... e+pressure http://www.ausmini.com/forums/viewtopic ... e+pressure http://www.ausmini.com/forums/viewtopic ... e+pressure |
Author: | boho [ Tue Jun 05, 2007 11:18 am ] |
Thanx, Spaceboy. Search is your friend. ![]() I run 32 rear and 34 front to accomodate the extra weight of the engine and am quite pleased with it. |
Author: | 1018cc [ Tue Jun 05, 2007 12:06 pm ] |
30f, 28r I think that's nice. Don't take someone's word for it though - adjust your pressures at some point and drive it - if it's too bumpity for you then lose 1 or 2psi and try again and see what you think. I decided on 30f and 28r because it still gives a smooth ride and my tyres wear evenly. |
