https://ausmini.com/forums/
needing help with bullet mirrors
https://ausmini.com/forums/viewtopic.php?f=2&t=32472
Page 1 of 2
Author:  minidrifter [ Mon Jun 04, 2007 4:21 pm ]
Post subject:  needing help with bullet mirrors
when i bought my mini it already had bullet mirrors fitted, the only problem is, i s that i cant see out of them? does anyone know how i can fix this problem?
Author:  Betty [ Mon Jun 04, 2007 4:40 pm ]
I had the sme problem, then i finally realised that you will never be able to see out of them :lol:
Author:  drmini in aust [ Mon Jun 04, 2007 4:42 pm ]
I have one on Barney and I can see OK. it all depends where you fit them, there is a sweet spot that works. :wink:
Author:  Wombat [ Mon Jun 04, 2007 4:47 pm ]
...................and that is??
Author:  drmini in aust [ Mon Jun 04, 2007 4:55 pm ]
Sit in car, twist mirror fully to side, then hold mirror with your right hand to the door when you can see properly to the rear. Your beautifil 1/2 clad assistant can then mark the position with a pencil and you're set. :lol:
ps. make sure to do this with quarter vent window opened....
Author:  Tadhg [ Mon Jun 04, 2007 5:35 pm ]
Would a photo be possible, Doc? Just to show us all the general area where the mirror should end up..? Please? :D
Author:  minidrifter [ Mon Jun 04, 2007 5:40 pm ]
that would work doc, but these are already fitted so cant really take em back out. :(
Author:  Hanra [ Mon Jun 04, 2007 6:01 pm ]
If you fit it here.....
you wont be able to see out of it...And you wont be able to use ur quarter glass.
Author:  lil-ute [ Mon Jun 04, 2007 6:03 pm ]
try a set of west coasters mine are heated aswell so i can see when they fog up
Author:  minidrifter [ Mon Jun 04, 2007 6:05 pm ]
ive wondered if you put it on the silver part of the door just after the quarter glass you might be able to see out of it and still use the quarter
Author:  drmini in aust [ Mon Jun 04, 2007 7:12 pm ]
Here's a pic of Barney with the PO driving... note the mirror is well forward. :wink:
Works fine for me too. 8)
Author:  minidrifter [ Mon Jun 04, 2007 8:00 pm ]
this is where mine are situated
Author:  Georgy Porgy [ Mon Jun 04, 2007 8:32 pm ]
Can also purchase one of the new ones that have the longer arm and movable body. I will be trying one in replace of the bullet that is on mine now.
It is currently further back than the ones in the photos so far and far enough back to open the 1/4 window.
Pete
Author:  Pinky! [ Mon Jun 04, 2007 8:59 pm ]
They just take a bit of getting used to in comparison with the stock ones. As long as they have a tight fit and don't vibrate all over the place it's fine :)
Author:  tinymorris1969 [ Mon Jun 04, 2007 9:19 pm ]
hmmm mines fitted like hanras but my forward bolt has been left off so i can move the whole unit and the mirror as well
