It is currently Thu Jun 26, 2025 9:46 pm
 Post subject: larger rubber cone
PostPosted: Sun Apr 22, 2007 8:44 pm
hey
can you buy a larger rubber cone for the suspention, i only need to raise it 20 mm,
exhaust is 85mm from the ground and the edge of the tyre is 12mm from the gaurd,
PostPosted: Sun Apr 22, 2007 8:48 pm
Get Hi-lows.
:D
For a sec I thought this thread c,ould be another spammer one! :D
PostPosted: Sun Apr 22, 2007 9:02 pm
The factory way of raising the car is to fit a washer between the cone and the knuckle joint.
The simple way is to fit Hi-lows.
The cheap way is to use a washer. :wink:
PostPosted: Sun Apr 22, 2007 9:06 pm
Oh yeah, if the cones have sagged, newies will make a big difference.
To raise the car 20mm the cones will only need to be 7mm higher.
:D
PostPosted: Sun Apr 22, 2007 9:08 pm
sweet as, i never thought of a washer, i was also thinking of welding a plate on the top of where the cone bounces on,
thanks guys
Users browsing this forum: MiniPete and 98 guests
