It is currently Fri Jun 27, 2025 10:40 am
 Post subject: A series or A +
PostPosted: Fri Feb 09, 2007 3:17 pm
What is better A series or A+ for 1. performance and 2. reliability
Morgs
PostPosted: Fri Feb 09, 2007 3:31 pm
At the end of the day it doesn't really matter. A+ basically means built after 1980something. If the engine is completely rebuilt, it shouldn't make a difference.
:D
PostPosted: Fri Feb 09, 2007 3:42 pm
I've heard the A+ blocks are thinner but as Harley said if its built/rebuilt properly it won't make much difference at all.
Gee thats a curly question.
Lets look at it logically. The A-series has been around for a long long time and at one stage or another a car powered by an A series engine has won virtually every motoring performace and relaibility prize.
Every engine has its archilles heel and the A-series is no exception. For a seventy year old engine it has been developed and developed until it produces up to 160 bhp but with very few re-engineering refinements.
The A plus engine was delevoped when Leyland/Rover found itself competing against hightech european and asian manufactures and losing sales becausing of it.
The re-engineering was an attempt to rectify some of the archiles heel but it was done under the watcher eye of cost accountants and you know what that means.
It is a smoother motor with less distortion of the block at higher revs. It is a much newer blcok in term of manufacture therefore less wear stress and crystalisation of the metal.
Is it better ??? Well IMO - yes but not so you would notice.
PostPosted: Fri Feb 09, 2007 3:44 pm
Die Die Die!!
gear changes in an A+ Engine are Much smoother.. and the engines tend to run a bit quieter
PostPosted: Fri Feb 09, 2007 3:59 pm
The A+ is a complete re-manufacture from the original A Series design. It incororates a few later technologies.
I find that the A+ is a little rougher running - ie more vibrations and noisey back into the cabin, but I've found that they are a lot more reliable.
admitedly my Cooper is an SPi, but its done over 250,000 kms without having the head off and still doesn't require any topups between 3 out of 4 oil changes (at 10,000km intervals)
PostPosted: Fri Feb 09, 2007 4:36 pm
IMO it depends solely on what you can get, at what price and in what condition.
PostPosted: Fri Feb 09, 2007 6:50 pm
It the end not much difference. Thanks for the info.
Morgs
