ABAC Compressor - 175ltr/min, 50 ltr tank, 2.5hp https://ausmini.com/forums/viewtopic.php?f=2&t=27855 |
Author: | birty [ Fri Feb 09, 2007 11:12 am ] |
Post subject: | ABAC Compressor - 175ltr/min, 50 ltr tank, 2.5hp |
Hi there, I found this air compressor in a shop here in Canberra and according to various topics this could do the job in painting a mini with minimal hassles. It costs $575 which is a bit but ADAC seems to have a good name. http://www.oztion.com.au/vshops/previewpic.aspx?shopid=1702&itemid=1166382&picnum=1#mypic I just can't justify renting an air compressor a few times for spraying as the rental costs will add up and I may as well have something to show for it. Does anyone have any experience with these compressors? Spray guns are another issue though. Many thanks in advance.[/url] |
Author: | Mick [ Fri Feb 09, 2007 2:15 pm ] |
And can a compressor brainiac tell me what the difference is between a belt drive 2.5HP compressor and a direct drive of the same HP? |
Author: | collins [ Fri Feb 09, 2007 3:53 pm ] |
Belt drive is softer starting and will last longer.... IMHO. Direct drive really hamers the pump more so than the belt drive. I agree that purchasing an aircompressor is the best savings as rental can add up very quickly. I just bought my 55l compressor vertical twin for similar money $615 and it was money well spent. ![]() |
Author: | drmini in aust [ Fri Feb 09, 2007 6:22 pm ] |
For a given HP rating, a belt drive compressor will move more air- it has a bigger (usually twin cylinder) pump running at lower rpm for improved volumetric efficiency. So, you get more air, and probably less heat. And a damn sight less noise. Also, the tank is usually bigger, so it lets you spray longer before pressure drops off. ![]() |
