rear demister problem https://ausmini.com/forums/viewtopic.php?f=2&t=27393 |
Author: | sociallydisabled [ Mon Jan 29, 2007 5:27 pm ] |
Post subject: | rear demister problem |
hey guys, im close to refitting my rear window, but i have a problem with my demister as the little connectors that were soldered on have broken off, is there a way to fix this or a replacement or what? |
Author: | 9YaTaH [ Mon Jan 29, 2007 6:23 pm ] |
Post subject: | Re: rear demister problem |
sociallydisabled wrote: hey guys, im close to refitting my rear window, but i have a problem with my demister as the little connectors that were soldered on have broken off, is there a way to fix this or a replacement or what?
You can carefully re-solder the connections on your Heated Rear Window element ![]() |
Author: | sociallydisabled [ Mon Jan 29, 2007 6:26 pm ] |
is that with just normal solder and a soldering iron ![]() |
Author: | rampage101 [ Mon Jan 29, 2007 6:34 pm ] |
Yep, I'm a window tinter by trade now, and occasionally we have these come off, including today on a HZ GTS, although it wouldn't matter because his won't be working now anyways. But yes, you just need to resolder it, try not to get solder splatter anywhere on the glass, and from memory it would need to be a fairly warm iron. |
Author: | sociallydisabled [ Mon Jan 29, 2007 7:01 pm ] |
ok cheers mate ![]() |
Author: | fffffred [ Sat May 01, 2021 12:19 am ] |
Anyone tried Permatex product? https://www.permatex.com/products/speci ... ?locale=en |
