https://ausmini.com/forums/
Gearboxes and clutches
https://ausmini.com/forums/viewtopic.php?f=2&t=271
Author:  leyland74 [ Fri Apr 09, 2004 3:45 pm ]
Post subject:  Gearboxes and clutches
I've been told mini's are hard to get into first/reverse sometimes, I'm guessing they don't have any synchomesh for those gears?
I have alot of trouble getting it into reverse and first, but also when in first or reverse and I've put my foot on the clutch for a minute or two (say at lights) it starts to engage and it's difficult to get out of gear. I adjusted the clucth according to Gregory and it doesn't seem to have made a difference.
Any help!
Author:  drmini in aust [ Fri Apr 09, 2004 4:10 pm ]
Sounds like clutch is dragging- you probably have a fluid leak or bad seals- either in the clutch master cylinder, or slave...
Author:  poeee [ Fri Apr 09, 2004 4:22 pm ]
Take a look at the slave cylinder first. Out of the 3 Mini's I own, one I have had to reco the slave cylinder and the other has a siezed one!
Author:  leyland74 [ Fri Apr 09, 2004 5:08 pm ]
It does look like the slave cylinder may be leaking. Is it hard to reco (or expensive?)
Author:  drmini in aust [ Fri Apr 09, 2004 6:00 pm ]
No, it's real easy, as long as the bore is not pitted.
Strip it and check- clean bore with some wet/dry paper- (or hone it if U got one)- usually it's just the rubber seal is old and worn out. Kit is cheap, so is a new cylinder! :wink:
Author:  leyland74 [ Fri Apr 09, 2004 6:09 pm ]
Thanks, will do. :)
Author:  Californian Moker [ Fri Apr 09, 2004 7:29 pm ]
Dont worry about reconditioning the one u have buy a whole new bastard i picked up mine off www.minidirectaus.com for 66 bux including shipping to adelaide took about 2 weeks and just gets put straight in.
Author:  drmini in aust [ Fri Apr 09, 2004 8:05 pm ]
$49.64 at Karcraft in Sydney, incl GST.
email is [email protected]
8)
Author:  leyland74 [ Fri Apr 09, 2004 8:43 pm ]
Thanks guys, will try that. :)
