Seats - Autotecnica or SAAS https://ausmini.com/forums/viewtopic.php?f=2&t=24091 |
Page 1 of 2 |
Author: | thedog74 [ Thu Oct 26, 2006 4:51 pm ] |
Post subject: | Seats - Autotecnica or SAAS |
I've done some searching of threads and found everyones putting in second hand seats into their cars. I wanted to get something new around the $800-$900 mark for 2 seats, and found both Autotecnica and saas seats at Repco. Are these any good and we're can you get rails from? Do they have to be engineered? (I've got a 72 Clubby. Any other suggestions for seats would be appreciated I'm in the Sydney area and getting desperate cause my seats suck big time...... |
Author: | buztoy [ Thu Oct 26, 2006 6:30 pm ] |
ive got those autotechinica monza seats in my celica and unless you have a non wide posture then they are good cruising seats, i got my cup seats out of a skyline, they were all cruddy but i recovered them using the frame, only cost me 70 bucks too |
Author: | Harley [ Thu Oct 26, 2006 6:35 pm ] |
I don't think they need 'engineering', as most adr's didn't kick in till about '74 I think. As long as it is good and solid it should be fine. Cobra have brackets available, but they cost around $100 each. ![]() |
Author: | buztoy [ Thu Oct 26, 2006 6:45 pm ] |
on the engineering side i bolted them straight on, i put 2 bolts straight throught the cross panel in the floor, |
Author: | Gadgets mini [ Thu Oct 26, 2006 7:30 pm ] |
have a look here http://www.soldsmart.com.au/l2.aspx?depts=4 i got me a seat for $159 and fitted it in a day very comfortable and fits the Mini well ![]() |
Author: | Razor [ Thu Oct 26, 2006 7:40 pm ] |
What size are the mounting bolts like thread and length? I'm planning to install different seats on mine cheers |
Author: | Hanra [ Thu Oct 26, 2006 8:01 pm ] |
They certainlly will need to be engineered. If u use after market mounts, that to will need to be engineered. If u use harnesses, that will also need to be engineered. Ive got Sparco's with modified Cobra frames, and SAAS harnesses. All had to be engineered and blue plated for RWC. Also needed to alter seating capacity down to 2. |
Author: | Siclad [ Thu Oct 26, 2006 8:41 pm ] |
was it a pricey process hanra? |
Author: | thedog74 [ Thu Oct 26, 2006 8:53 pm ] |
I also need a new backseat now, on the way home, my car jack jumped onto the positive terminal and my back seat caught on fire, fried my battery and caused some nice damage to the interior. If anyone was on the way home from the city (sydney) at about 5:30 tonight that was me on the entrance to the Anzac bridge, stamping out flames. |
Author: | Hanra [ Thu Oct 26, 2006 8:54 pm ] |
Not really, cant remember the dollar figures, but basically just had to keep in touch with the Engineer, he advised me what needed to be dont for it to pass. I had to modify the Cobra seat frame thou. He wanted them completly bolted to the floor, so it was unable to pivot like a standard seat can. Also needed to be plated underneath the floor where it was mounted. Also the harnesses are obvilously plated under the floor at there mounting points also. Was a bit of stuffing around, but the Engineer advised me who to take it to, to get the work done. So he was happy with the welds n stuff that were done to the frame for it to suit the Sparco Seat. |
Author: | harvey69 [ Thu Oct 26, 2006 9:06 pm ] |
Gadgets mini wrote: have a look here
http://www.soldsmart.com.au/l2.aspx?depts=4 i got me a seat for $159 and fitted it in a day very comfortable and fits the Mini well ![]() i dont mind the look of these ones.... http://www.soldsmart.com.au/l3.aspx?goods=CS7022KE |
Author: | Razor [ Thu Oct 26, 2006 9:20 pm ] |
ooooh I wouldnt mind taking my mini to get the seat conversion done and blue plated... I remembered before there's a company in brisbane i found and told me that it will be around $300+ for installation including blue plate but you have to supply the seats and must be ADR complied or from another car with rails |
Author: | Hanra [ Thu Oct 26, 2006 10:31 pm ] |
thedog74 wrote: I also need a new backseat now, on the way home, my car jack jumped onto the positive terminal and my back seat caught on fire, fried my battery and caused some nice damage to the interior. If anyone was on the way home from the city (sydney) at about 5:30 tonight that was me on the entrance to the Anzac bridge, stamping out flames.
WTF???? |
Author: | Siclad [ Thu Oct 26, 2006 10:35 pm ] |
random eh... |
Author: | dove grey 64 [ Fri Oct 27, 2006 8:42 am ] |
im not too sure but i remember SAAS being a better company then autotecnica |
