It is currently Fri Jul 25, 2025 9:28 am
 Post subject: Smaller spacer drums
PostPosted: Fri Oct 27, 2006 9:26 am
Gday,
I have just aquired two brake drums, they are the spacer drums but the spacer is smaller than the normal S ones. I read an earlier thread that said they could be off a Moke. If they are, does this mean they are exactly the same as S drums except for the spacer width? I don't want to get them machined and not be able to use them on my mini.
Thanks all
Steve.
PostPosted: Fri Oct 27, 2006 9:33 am
Yes they would be moke drums 3/4 inch spacer instead of 1 inch for the others , they should fit and are a rae item these days :D
Jon
Yes, identical to a Mini spacer one except the `spacer' width is 1/4" less.
PostPosted: Fri Oct 27, 2006 10:11 am
Thanks guys, that's great, I didn't measure the spacer but 1/4 inch sounds about right. I think I have a dodgy drum on my car at the moment, so hopefully these 2 are ok and i can fix the problem.
Steve.
