Pulls to the left... https://ausmini.com/forums/viewtopic.php?f=2&t=24089 |
Page 1 of 2 |
Author: | boho [ Thu Oct 26, 2006 1:16 pm ] |
Post subject: | Pulls to the left... |
Howdy folks. Got a slight pull to the left in the Open Classic whilst driving which sometimes gets exaggerated when braking during a left turn. Is this a balance or alignment problem? Thanx in advance for help. ![]() Oh, and Cush, no need for any comments about MY pulling to the left... ![]() |
Author: | simon k [ Thu Oct 26, 2006 1:41 pm ] |
a looseness problem - if it's come on all of a sudden, get it checked cos something is coming adrift.... caster different from one side to the other will cause it to pull to one side, as will a dragging brake and any number of other things really hard to diagnose over the internet ![]() |
Author: | boho [ Thu Oct 26, 2006 1:43 pm ] |
Thanx, sks. Just asking re my tyre post - need new tyres but don't wanna waste money getting a full alignment done if i only need balances... ![]() |
Author: | simon k [ Thu Oct 26, 2006 1:53 pm ] |
I didn't see your tyre post, but I called my wheel alignment bloke last week to book in for an alignment before I went to Sydney - he always asks why I want one.... this time I said I'd put adjustable tie bars on, longer lower arms and 12" wheels - it tramlines a lot... he asked if the car pulled in any direction "no", he asked if the tyres were getting scrubbed "no", he asked if the 12" wheels are wider than the 10"s I had "yes".... well the tramlining is caused by the wide wheels accentuating the increased negative camber - nothing else was wrong cos it doesn't pull and doesn't scrub if your tyres don't scrub, you don't *need* an alignment, balancing stops the tyres from shuddering at speed..... but pulling to one side is always a concern |
Author: | boho [ Thu Oct 26, 2006 1:55 pm ] |
scrub? ![]() |
Author: | simon k [ Thu Oct 26, 2006 2:22 pm ] |
BohoMini wrote: scrub?
![]() uneven tread wear... like the tyre is wearing on one side of the tread but not the other if you've never had your alignment done, it's worth it - some people even find a marked performance improvement because their tyres aren't fighting each other to go in a straight line |
Author: | boho [ Thu Oct 26, 2006 2:24 pm ] |
Thanx, please excuse my ignorance... I am learning! (Slowly... ![]() I haven't had it done since i bought it in January and haven't the foggiest when matt had it done before then, so i might just go ahead and do it. ![]() |
Author: | simon k [ Thu Oct 26, 2006 2:34 pm ] |
BohoMini wrote: Thanx, please excuse my ignorance... I am learning! (Slowly...
![]() I haven't had it done since i bought it in January and haven't the foggiest when matt had it done before then, so i might just go ahead and do it. ![]() it's OK, we all start somewhere.... ![]() if the alignment was done in January, and nothing has changed since, then there shouldn't be any need to have it done again - as my wheel alignment bloke says "if nothing has changed, then nothing needs to be changed" I suggest a trip to Link or Minis Plus so see about that pulling - you haven't said whether it's started happening all of a sudden or has always been there |
Author: | boho [ Thu Oct 26, 2006 2:38 pm ] |
Sorry, misunderstanding. It's been happening on and off since i got it in January and i have not had it aligned at any point while i have owned it. |
Author: | simon k [ Thu Oct 26, 2006 2:44 pm ] |
BohoMini wrote: Sorry, misunderstanding. It's been happening on and off since i got it in January and i have not had it aligned at any point while i have owned it.
ahh - OK then... happening on and off doesn't sound good, at all - something occasionally loose, and occasionally tight - scary! Pottsy recommended Ralph Perluzzo at TruTrack in West Melbourne in the last VMCI mag - grab your white pages and make a booking ![]() make sure when you go, that you explain that there is an intermittent pulling to one side, and if you can, watch what he's doing so you can get a bit of an understanding |
Author: | boho [ Thu Oct 26, 2006 2:54 pm ] |
I'll look into it. Thanx for all your help! ![]() |
Author: | andbat [ Thu Oct 26, 2006 4:59 pm ] |
molly use to pull to the left, i put new tyres on her and now she pulls to the right. she has so much personality. |
Author: | simon k [ Thu Oct 26, 2006 5:03 pm ] |
andbat wrote: molly use to pull to the left, i put new tyres on her and now she pulls to the right. she has so much personality.
![]() ![]() hey Boho... have a think about when that problem comes and goes... .does it co-incide with anything like putting air in the tyres? |
Author: | Morris 1100 [ Thu Oct 26, 2006 5:55 pm ] |
skssgn wrote: ... .does it co-incide with anything like putting air in the tyres? Or changing lanes? ![]() Pulling to one direction is usually related to castor but you need to make sure that everything else is Ok. The rubbers on the front of the tie-rod (castor-rod) can cause problems but so can a bent rod. |
Author: | 9YaTaH [ Thu Oct 26, 2006 6:38 pm ] |
Post subject: | Re: Pulls to the left... |
BohoMini wrote: Howdy folks.
Got a slight pull to the left in the Open Classic whilst driving which sometimes gets exaggerated when braking during a left turn. Is this a balance or alignment problem? Thanx in advance for help. ![]() Oh, and Cush, no need for any comments about MY pulling to the left... ![]() Could also just be a dragging brake or weeping wheel cylinder causing that side to grab...either way, it needs investigation and sorting before its driven in the wet...unless you like unexpected left turns ![]() EDIT: Mini Classic?? Disk brakes?? you could still have issues with a sticking caliper or undersize rotor. |
