It is currently Mon Jul 28, 2025 11:44 pm
PostPosted: Thu Oct 26, 2006 12:22 pm
yes thats right.... I was changing a tire on my '77 leyland mini van, and everything went well, except once I had finished, I noticed that my windscreen had cracks all through it.
I'm just wondering if there is something obvious that I did wrong, or if I jacked the car up in the wrong place or something?
Anyone else had this happen to them?
cheers.
Andrew.
PostPosted: Thu Oct 26, 2006 12:32 pm
Sounds like u flex ya shell a bit!!! Was it front or rear tyre? Where did u jack the car from?
PostPosted: Thu Oct 26, 2006 12:43 pm
The rubber in the windscreen frame should have flexed before the whole shell put weight on the glass itself.
Old laminated screens are very touchy though. Many windscreen fitters refuse to touch a second hand one.
PostPosted: Thu Oct 26, 2006 12:46 pm
where did you jack it up from?
PostPosted: Thu Oct 26, 2006 12:50 pm
Rides with Flex master Flex!
PostPosted: Thu Oct 26, 2006 2:28 pm
I was replacing the front right wheel.
And I jacked the car up about 2/3 of the way between the two wheels - closer to the front right (obviously).
I need to swap that wheel off again, but i'm scared i'll crack the new windscreen!!!
PostPosted: Thu Oct 26, 2006 3:05 pm
Put the jack underneath ur front subframe. If u have a new laminated safety screen fitted now, u should be ok.
PostPosted: Thu Oct 26, 2006 4:19 pm
and if you dont and it cracks..take it back
PostPosted: Thu Oct 26, 2006 6:36 pm
or pm us because i dont wont to throw this windscreen out,
