It is currently Mon Jul 28, 2025 6:17 am
 Post subject: Water pumps
PostPosted: Thu Oct 26, 2006 9:40 pm
There are 2 water pumps right? Standard and high volume?
What happens if you run a standard on a 1275?
PostPosted: Thu Oct 26, 2006 9:45 pm
It works just slightly less effective. Oh, and I'd argue there are 4 types, standard with pressed steel impellor :shock: , standard with cast impellor, high volume with bypass hose and also without :wink:
I was shocked recently after pulling my Cooper 1275 down for a mild refit that after ten years it had been running a standard pressed metal water pump....hmmm...I must have been a little short of cash at the time I can't remember...besides that it did a fantastic job and survived 6 years in Darwin then Victoria and Sydney and WA.
The impeller was pitted but still it worked OK. It helps that the rest of the system was up to scratch as well though.
I turfed it anyway to the spares bucket for a hi flow for good luck.
PostPosted: Thu Oct 26, 2006 9:48 pm
Thanks guys. 8)
Rebuilding my GT motor at the moment and I had a new spare standard water pump. Wasn't sure if it would be suitable.
