https://ausmini.com/forums/
Throttle cable
https://ausmini.com/forums/viewtopic.php?f=2&t=24062
Author:  Blokeinamoke [ Wed Oct 25, 2006 9:04 pm ]
Post subject:  Throttle cable
The bloody throttle cable snapped in the middle. Glad it happened now.
I will replace it with a generic, however any ideas on how to add the lumpy bit, that fits into the accelerator pedal, onto the cable?
Author:  Mick [ Wed Oct 25, 2006 9:06 pm ]
Bicycle cables have a very similar lump on the end. You can lash out and get a teflon lined you beauty cable for 7 bucks. Cross fit the brass end fittings from the old outer cable if you have them.
Author:  Blokeinamoke [ Wed Oct 25, 2006 9:07 pm ]
Hero. Thanks.
Author:  Mick [ Wed Oct 25, 2006 9:10 pm ]
Oh, Grease it before you re-install it.
Author:  Morris 1100 [ Wed Oct 25, 2006 9:17 pm ]
Don't over adjust it. You want the pedal on the floor with the butterfly 99% open. :wink:
If you have 100% throttle and the pedal just off the floor you will break the cable very quickly.
Author:  Blokeinamoke [ Wed Oct 25, 2006 9:19 pm ]
Yep. Thanks
Author:  Betty [ Wed Oct 25, 2006 10:35 pm ]
speak to Mini Mad about throttle cables snapping.
That is his profession ! :!:
Author:  Rikki [ Fri Oct 27, 2006 7:48 pm ]
I have a push bike cable as a throttle cable and it works perfectly. :D
Author:  aaron [ Sat Oct 28, 2006 8:25 am ]
ONe trick with push bike accelerator cables is to cut the excess off with an angle grinder cutting disc rather than a pair of cutters. This will help stop the indiviual wires being crushed and mishaped so that you can still fit it to the carb. If you have a good soldering iron get it really hot and dab a touch of solder on the end to hold the wires. Just a few tips to making life easy. :wink:
Aaron
Author:  Blokeinamoke [ Sat Oct 28, 2006 8:29 am ]
Aaron
I tried two bike cables and they both freyed at the end of the sheath where it goes throurgh the firewall. Mind you they ware rubbish chinese things. So I have ordered a teflon coated core and a new sheath. Thanks for the feedback. Might make a good How-To :wink:
