It is currently Sun Jul 20, 2025 10:15 pm
PostPosted: Fri Oct 27, 2006 4:04 pm
It's starting to bug me. The horn button is located on the passengers side of the center switches (next to the wipers). It's been like that since I bought it, some five years ago, but it's starting to bug me now for some reason. A clubby indicator stalk wont fit a roundy without a bit of modification to the outer column as far as I know, and it needs a different shroud. I don't want to install the whole column because it's a fair bit shorter. And I have a formuling wheel with no provision for a horn button.
Where else can I put it, that's within easy reach?
PostPosted: Fri Oct 27, 2006 4:13 pm
What about a horn button mounted on the steering wheel spoke with a telephone cord like lead (from Jaycar or Dick Smith) connecting to the steering column, that would probably look pretty OK....
Or fit a clubby column and shroud and indicator?
Just thoughts....
PostPosted: Fri Oct 27, 2006 4:16 pm
Anto,
My 1970 matic has the clubby horn button, what year is your car, you must have the old Mk1 setup. Indicator light on the end of blinker switch?
PostPosted: Fri Oct 27, 2006 6:21 pm
Anto,
Yup, that's the one, although there isn't a light on the end anymore, just a long chrome stick :)
I was looking at clubby style blinker stalks, looks like you could fit it but would have to remove the tabs to hold the original shroud on, which means no going back...
<edit>Was just looking at it now, looks like a clubby one will fit without removing the tabs, it doesn't quite line up perfectly with the canceller bolt but still works. Interestingly the reason my indicators never ever cancelled properly might just be because the canceller bolt points in the wrong direction to cancel at the right time!
PostPosted: Fri Oct 27, 2006 7:50 pm
Just thoughts....
ive got that set up only every 3rd round about you need to do a bit of untangling
PostPosted: Fri Oct 27, 2006 9:21 pm
Anto wrote:
Anto,
I think you should be able to fit a clubman indicator stalk without modifications, but yeah, you need the clubman shroud....
on the self cancelling - the bolt in the bottom of the steering column should be at horizontal, and closest to the floor when the wheels are pointing straight ahead, then the canceller lug will be in the right spot ;) it was designed that way :shock:
what sort of steering wheel do you have? can you hook up the centre button?
PostPosted: Fri Oct 27, 2006 9:48 pm
Put a foot pedal for the horn, so when you slam the breakes you can also slam the horn, o but which leg will do the clutch :P
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Fri Oct 27, 2006 10:35 pm
I've got a formuling wheel and it can't take a horn button. At the moment when the steering is pointing straight ahead the canceller lug on the column points straight up, which I don't think is right. I'll check it all tomorrow and try to get it right.
PostPosted: Fri Oct 27, 2006 10:43 pm
yeah, pull the wheel off the column, pull the column off and turn it around - later cars had a mark in the end of the column pointing up, but yours wouldn't have it....
turn the wheel all the way one way and then half way back to find the centre ;)
PostPosted: Fri Oct 27, 2006 10:45 pm
Get that bumper sticker.... "Horn broken watch for finger"
PostPosted: Sat Oct 28, 2006 8:28 am
just watch for the finger anyways
Users browsing this forum: No registered users and 72 guests
