It is currently Wed Aug 20, 2025 4:19 am
 Post subject: I can't floor it
PostPosted: Mon Oct 23, 2006 10:51 am
On the weekend I put a kit into the HS4 on my car as the jet was badly worn, now it cruses along fine but when I put the foot to the floor the engine dies, whats going on?
PostPosted: Mon Oct 23, 2006 10:54 am
did you remember to put oil in the dashpot>?
PostPosted: Mon Oct 23, 2006 11:08 am
yes the pot is all oiled up
PostPosted: Mon Oct 23, 2006 12:33 pm
Did u centre the jet? Did u confirm that the needle and piston assy move freely and dont bind up?
PostPosted: Mon Oct 23, 2006 2:02 pm
ok, it's fixed now, not sure what it was I just replaced the air filter and it started working properly
PostPosted: Mon Oct 23, 2006 3:06 pm
Just because it started working again dosnt mean anything. Did u centre the jet correctly when u replaced it? If u lift the piston up inside the dash pot is it able to move freely? Can u hear a metalic clink when it falls back down?
PostPosted: Mon Oct 23, 2006 6:05 pm
Yeah I checked everything before I put it back together and after it was back together, seems to be running fine now but I will get it tuned properly tomorrow, will see how it goes then.
PostPosted: Mon Oct 23, 2006 6:14 pm
I had this exact same problem on the standard su on my 998cc, I hadn't touched anything, however it was running without an air filter at the time (wasn't going anywhere but my garage anyway), then out of no where it started working normally again. However, mine was doing it when I revved the engine in neutral, not driving.
Users browsing this forum: No registered users and 395 guests
