It is currently Mon Aug 18, 2025 8:27 pm
 Post subject: Magnolia 3 Clock gauge
PostPosted: Mon Sep 18, 2006 10:23 pm
Is this a hard conversion from a 3 clock australian gauge to UK magnolia 3 clock gauge?
1st issue is the speedo, its Miles instead of Kilometers (speedo needs calibration?)
Wiring? the printed circuit board looks very similar, it should have the same basic wiring anyway right
I'm sure someone here has done the conversion
PostPosted: Mon Sep 18, 2006 10:30 pm
My magnolias have both mph and kph.
Can't you just fit the faces? 8)
PostPosted: Mon Sep 18, 2006 10:32 pm
you can get the faces from minispares right?
PostPosted: Mon Sep 18, 2006 10:38 pm
it does have kph in smaller writing, didnt notice that...
I can also design my own and print it on photo paper with adhesive backing
PostPosted: Mon Sep 18, 2006 10:40 pm
Yes you can, but I'm not 100% sure they'll fit.
The minispares description may help.
If it does work it will save you a good $200 easy! :D
PostPosted: Tue Sep 19, 2006 7:32 am
rev counter is the hard part as nothing else is different as the rev counter is designed to fit a twin point injection mini and the pisck up points are differnt so your rev counter tends to double the revs, i had to calibrate my own, quite easy with 2 screws in the back of the counter you just set up another rev counter and adjust till the same.
they are great look clocks and i have a sticker on mine that says "they are colour coded to match your knuckles".
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Mon Oct 09, 2006 5:55 pm
how do you adjust or calibrate the tacho with the two screws at the back?
are all the wiring the same from a stock clubman?
is it a plug & play thing?
PostPosted: Mon Oct 23, 2006 8:48 pm
I installed a set of magnolia 3 clock gauge today and hoping the tacho will work...and it did!!!
thought everything was working but tonight wanted to see it illuminated but no dash lights, indicators work, high beam, and the battery signal light are all working
any ideas?
Users browsing this forum: No registered users and 312 guests
