alternator smoking! https://ausmini.com/forums/viewtopic.php?f=2&t=21049 |
Author: | thomen [ Fri Aug 04, 2006 9:33 am ] |
Post subject: | alternator smoking! |
hi all i rewired my battery cables and on the positive (aka live terminal) of the solenoid i reconnected the battery cable, altenator cables etc (as were previously there) and then alas turned on the key and smoke poured out of my engine bay via the brand new alt... im going to take it to a sparky... but just wondering out of interest what you guys think could have caused it besides my inherent stoopidity!? |
Author: | Mick [ Fri Aug 04, 2006 12:33 pm ] |
May still be the alternator yet, but I don't think so. Perhaps you wired the 12 volts from the soleoid to a ground connection on the alternator instead of the field? What were your connections? |
Author: | awdmoke [ Fri Aug 04, 2006 12:39 pm ] |
Once you let the smoke out of the alternator it won't work ![]() Sounds like you crossed something over & shorted it out. The sparky can test your alternator & repair/replace as necessary. Take along a spare if you have one (but get any used ones tested before you fit it). |
Author: | drmini in aust [ Fri Aug 04, 2006 4:22 pm ] |
If you put the battery in backwards (making it pos earth) with an alternator, it will do that. They all MUST be NEG earth. It's terminal, (pardon the pun). Will need a new rectifier stack in the alternator, at least. ![]() |
Author: | TheMiniMan [ Fri Aug 04, 2006 7:58 pm ] |
hee hee,,,good one Kev,,,"Terminal",,, LoL a bit like when you`re affraid of flying in aeroplanes & you get to the airport & it says "TERMINAL" ![]() |
Author: | morphias [ Mon Aug 07, 2006 11:38 am ] |
TheMiniMan wrote: hee hee,,,good one Kev,,,"Terminal",,, LoL
a bit like when you`re affraid of flying in aeroplanes & you get to the airport & it says "TERMINAL" ![]() Or that you suffer from 'terra firma'. The less firm, the more terra! ![]() |
