It is currently Sun Jun 22, 2025 3:14 pm
PostPosted: Thu Apr 01, 2004 3:31 am
Hello everybody, good to see normality coming back after recent events (<--- pointless comment as a starter tool to show that I care and not only come here when I need something).
So obviously the result is lots more frustration (sexual and otherwise) and a bottom dash rail covered in tiny tears - not the crying type but the ripping the vinyl apart with a screwdriver type.
[bold] Where can I get it reapholstered in vinyl (good and cheap preferably) and how much would it hurt approximately? How hard is it toI dot myself? has anyone tried?
Also How do you install those Riley Elf Veneer dashes - I was trying to install it too and cant find the spots to mount it and the right position for it.
Where can I reveneer the dash - is it possible at home?
PostPosted: Thu Apr 01, 2004 9:02 am
Riley Elf dashboard simply attach over the central speedo. They don't attach to any part of the car, but rely on gravity to hold them in (mine always used to fall into my lap on acceleration :) )
Reveneering is an interesting question. It is what I am *trying* to do to mine. However, veneering round the bends in the dash is tricky (I'm told soaking the veneer in ammonia can soften it up) and veneering round the speedo hole can be tricky, depending on the style of dash.
It can be done at home, however a degree of experience in this type of thing would help - which I don't have hence why my wood dashboard is in storage at the moment!
PostPosted: Thu Apr 01, 2004 8:53 pm
Anyways, I was trying to install a 1970's Autoplas dash but when I took everything apart I realised that the lovely monkey of a previous owner (aren't they all) welded the top and bottom dash rails to the body (they werent welded originaly were they?)
But being single and full of sexual frustration and since I bought all the gauges to go in the dash already and was searching for it in the UK for 4 months I decided to try and install it anyway.
it is pretty easy to cover in vinyl
do you have a compressor and heat gun ? where are you located ?
lookin for another clubby
PostPosted: Fri Apr 02, 2004 1:51 am
No and no - do I need them to apply the vinyl (I guess heat gun to get the vinyl to spread? but compressor?
I'm in Coogee, Eastern burbs - I think I was talking to you a while ago about buying some parts but never got to it since the car went to the mechanic for two weeks.
PostPosted: Fri Apr 02, 2004 10:34 am
a heat gun is for heating and stretching the vinyl and a compressor is for applying the contact adhesive to glue the vinyl on
PostPosted: Fri Apr 02, 2004 10:49 am
so would that mean that us dodgy people could just normal contact adhesive? the kind of stuff u get in a caulking gun? :?
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
PostPosted: Fri Apr 02, 2004 2:44 pm
So without those two the job would be shite? Should I rent them or something?
PostPosted: Fri Apr 02, 2004 6:33 pm
i think u r thinking of liquid nails lol , u can get contact adhesive in aerosol form , just cheaper if u have a compressor. a heat gun is deffinately needed tho maybbe i could help u do it 1 wekend or sumfin?
PostPosted: Fri Apr 02, 2004 9:27 pm
Our local Spoiler shop sells a product for customising the interiour of you car thats a film that can be moulded with a hair dryer. Comes in 7 (I think) different styles: Silver Carbon fibre, Black Carbon fibre, Brushed Aluminium, Walnut, Teak, etc, etc and a few different colour vinyl finishes. Might be worth a look. Ive not actually seen anyone use it but the results in the shop looked quite good and they said its easy to use. No idea what its called or costs though.
PostPosted: Sat Apr 03, 2004 2:43 am
I reckon you've got yourself a date - if you already didnt gather what I want from my fake "should I rent them or something" comment.
I might pick u that heater from you too if you still got it.
I think I've got your number too.
Michael
 Post subject: Dash covering
PostPosted: Sat Apr 03, 2004 11:45 pm
I re-covered the top dash of my old clubbie van with vinyl and contact adhesive, it was a sh*t of a job, but came up great in the end.
As for re-veneering, Bunnings (Victorian hardware chain) sell sheets of wood veneer that you iron on (literally). It is pre-glued (heat activated).
I did my old Deluxe's dash with it, it's real wood, comes in varying grains/wood types, but varnished up nicely.
Due to lack of interest, tomorrow has been cancelled....
PostPosted: Sun Apr 04, 2004 4:49 am
How do you remove the old veneer? (I dunno anything about woodwork).
 Post subject: Veneer
PostPosted: Sun Apr 04, 2004 7:07 am
Yeah, luckily it was sun damaged and split, so I was able to get a thin metal scraper under it in most places, took quite a while, but the end result was worth it. Orbital sanders are great for the tidying up.
I basically left the speedo area's champhered egde as it was, no idea how you'd be able to do the circular and angled bit... :oops:
PostPosted: Sun Apr 04, 2004 5:59 pm
In regards to the veneer, it would all depend on what sort of veneer you would like to apply. you can get burr walnut (the standard swirly grain) which is beautiful but due to the nature of burr timber (that of which is from a defective part of the tree) it tends to break when you bend it..
if you go with a walnut or otherwise which is designed as a timber veneer for internal domestic purposes it will usually be very flexible and have an adhesive back that when heated will assist with adhesion.. its simply a case of putting in place then using a hot iron and dry tea towel to make the veneer stick perfectly.. this type of veneer should comfortably do a 6mm radius edge without cracking..
failing that you can use a product called kwik grip which is made by selleys .. it comes in a maroon tin (500ml 1L etc) and is a very strong contact adhesive especially designed for laminating or veneer applications such as this one..
in regards to the vinyl you can use a product called gel grip made by selleys again but is more flexible and will tend to dry spongy so not to make the vinyl go like a peice of plywood :) it comes in a green tin and same sizes as prementioned kwik grip..
both of the adhesives are about 10$ per litre and the veneer can cost around 50$ for a sheet large enough to redash the mini...
if you have any other questions ask away, oh btw i work at bunnings ;o)
PostPosted: Sun Apr 04, 2004 6:01 pm
unfortunately to remove the old veneer its just a scraper (like a spak filler applicator, metal edged putty knife type) and alot of elbow grease.. dont worry so much if you make a few grooves with the knife cos you willl cover that with the veneer :)
Users browsing this forum: slacko and 97 guests
