It is currently Fri Jul 18, 2025 10:10 pm
 Post subject: 1974 Mini Panel Van
PostPosted: Sun Jan 29, 2006 6:38 pm
Hi we have just purchased today a 1974 Mini Van (how can I tell if it is a Clubman?) It is a Leyland. Chassis No starts with 99H so I know it has a 1000cc engine. It needs some restoration but it has its original engine plus a new one purchased, also came with new muffler.
Young lad had started the restoration but I guess gave up so his parents were sick of it sitting in the carport and we heard about it.
Whooppee it will be great when it is going. :D [/img]
 Post subject: Re: 1974 Mini Panel Van
PostPosted: Sun Jan 29, 2006 6:42 pm
"Clubmans", be theysedans or vans, have a square front.
Your engine number starts with 99H.... :D
PostPosted: Sun Jan 29, 2006 6:54 pm
Welcome to the group , basically a clubman is the squarenosed version of the mini , our local ones were produced under the banner of Leyland between 1972 and 1978 , they were available as vans or sedans and looked basically like this
The earlier ones produced in Australia by Morris up until 1972 were often referred to (well , here anyway) as roundnoses or roundies and have the front like this .
Good luck with your project .
PostPosted: Sun Jan 29, 2006 7:17 pm
this is my 1974 Leyland Van
if it looks like this it is a 'Clubman'
BTW please post some pics up :wink:
PostPosted: Sun Jan 29, 2006 8:31 pm
hey sports850, you wouldnt have another ss poster you would sell me would you?
off to NT I go
PostPosted: Sun Jan 29, 2006 8:34 pm
Mini Clubman 1972 to 1973.
Leyland Mini 1973 to 1978
Done
PostPosted: Sun Jan 29, 2006 8:35 pm
I'm affraid not , it's my only one . ALso , it's too big for any of the scanners locally . I have 4 different Moke ones as well and would love to be able to copy and reproduce them but nowhere here can handle them , I've heard of a suitable scanner in a SYdney printers but they want over a hundred bucks to scan something that big and then "art and design " fee's on top of that .....
PostPosted: Sun Jan 29, 2006 9:21 pm
Have you tried scanning it in sections, then using like photoshop to "weave" the overlap together to rebuild the image? Maybe not perfect, but worth a go.
PostPosted: Mon Jan 30, 2006 6:40 pm
Done
Where does my 1971 Morris Clubman fit in there? :D
1974 Moke - 998cc
PostPosted: Mon Jan 30, 2006 6:43 pm
[quote="13secmini
Where does my 1971 Morris Clubman fit in there? :D[/quote]
In with most of the other wierd things BMC and BLMC did . That file must be bigger than the list of standard models . There was a one owner clubman in Maclean up until it was wrecked a few years ago that was 100% clubman outside and 100% roundy on the inside , centre speedo and all . The ex BLMC dealer was still servicing it and said it was as they delivered it . It was on the changeover and obviously they had some roundy interior bits they wanted to use ......
PostPosted: Tue Jan 31, 2006 5:16 pm
I had a '71 clubman which was like this, centre speedo, no top dash, but it did have the bottom dash pad and leyland switch panel, but with centre ignition, and non-locking steering column.
Poor little thing is no longer with us tho..
'78 LS 1275
PostPosted: Wed Feb 01, 2006 7:37 pm
Hi guys
Most of you say it is a clubman except one who said it was a Leyland Mini. Do I assume I can call it a Leyland Mini Clubman?
I will post some pictures later of it as we purchased it.
What is their value - does anyone know?
Maureen
