Steering rack https://ausmini.com/forums/viewtopic.php?f=2&t=15682 |
Author: | chasg [ Mon Jan 30, 2006 8:38 pm ] |
Post subject: | Steering rack |
My steering rack has developed a knocking noise from the pinion housing assembly. When the car is jacked up and you rotate the rack you can feel the knocking noise through the assembly. I believe this is due to excessive play in the housins assembly. I read someware that you can take off the end cover and remove shims to adjust any excess play is this so ? |
Author: | 9YaTaH [ Mon Jan 30, 2006 8:49 pm ] |
Post subject: | Re: Steering rack |
chasg wrote: My steering rack has developed a knocking noise from the pinion housing assembly. When the car is jacked up and you rotate the rack you can feel the knocking noise through the assembly. I believe this is due to excessive play in the housins assembly. I read someware that you can take off the end cover and remove shims to adjust any excess play is this so ?
Go and get an exchange rack....unless you really know what you are doing it just ain't worth the possibility of losing your steering ![]() |
