https://ausmini.com/forums/
Lsee's new motor...
https://ausmini.com/forums/viewtopic.php?f=2&t=15666
Author:  Smokie [ Mon Jan 30, 2006 12:22 pm ]
Post subject:  Lsee's new motor...
I am starting to put together a new motor for the LS.. Bought the 1049cc one off ebay and a 12G202 head off deluxe_68.
The engine is getting stripped down to make sure all is ok plus check what sort of cam it has in it..
What I would like to know is what sort of rockers I should use.. Forged, Pressed or 1.5 Roller Rockers??
I will be putting in a lightweight flywheel, single 1-1/2" SU??, electronic dissie plus what ever else it will need to give it a bit more go power.
I am also putting in a new 3 core radiator and a high flow water pump..
Author:  13secmini [ Mon Jan 30, 2006 6:35 pm ]
from what ive heard there is little if any hp increase (1-4hp) from the stock rockers to big $ rollers. Spend the money on some nice LCB extractors instead.
Author:  drmini in aust [ Mon Jan 30, 2006 7:28 pm ]
Best rockers for a smallbore most tuners reckon are the pressed steel ones. The early 1275 ones with the oval pads are best.
Unless it's a race motor forget 1.5s.. they really only work in 1275s.
I reckon the late Clubby and A+ sintered ones are rubbish... and they tend to wear the ends of valve stems when they get a bit of wear.
I suppose 1.3 rollers would look schmick, but who can afford them here.. :lol:
Author:  Smokie [ Mon Jan 30, 2006 8:03 pm ]
13secmini, already have spent the money on extractors so no probs there..
Looks like that is the way I will go then Doc...
