It is currently Sat Jul 19, 2025 1:08 am
 Post subject: 1970 deluxe on ebay
PostPosted: Tue Jan 31, 2006 10:58 am
http://cgi.ebay.com.au/Morris-Mini-1970 ... dZViewItem
Anyone know anything about this one or the seller ? cheers
PostPosted: Tue Jan 31, 2006 5:19 pm
I know that they didn't make Deluxes in 1970. 8)
PostPosted: Tue Jan 31, 2006 6:08 pm
They did make deluxes in 1970, it is a MKII deluxe mini K early 70 just before the antiburst lift up door handle model.
Push button due to stufed electrics and doggy modifications as demonstrated by the doggy mounting of the switch panel.
Might be alright if nothing is lurking under the outsides new paint and it goes cheap. If not wait till it comes back up for sale by the next person who decides it to bigger job
Jeez sorry I'm feeling cinical today
steve
PostPosted: Tue Jan 31, 2006 7:12 pm
The hydrolastic suspension needs fixing. Is that expensive?
67 Deluxe under going full resto
PostPosted: Tue Jan 31, 2006 7:27 pm
Depends whats wrong with it.. If it just needs a pump up it probably wont be expensive.. but if theres other problems.. might need an overhaul...
PostPosted: Tue Jan 31, 2006 10:29 pm
Is an overhaul costly?
PostPosted: Wed Feb 01, 2006 5:54 am
Apart from the hydro displacers and piping, most of the rest is stocko Mini suspension parts- knuckle joints, balljoints, etc.
Once fluid pressure is let out they are easy to work on.
Suspension parts are cheap, only added expense is pumping the hydro back up with fluid.
If a displacer or a pipe springs a leak, replacement is the usual option, although pipes can be repaired with fittings from Pirtek etc.
New displacers are NLA, but with minor mods it is possible to replace hoses..
PostPosted: Wed Feb 01, 2006 12:01 pm
Thanks for the replies. I feel suss about the seller, so I'm not going to follow it further.
PostPosted: Wed Feb 01, 2006 5:24 pm
It seems sus to me too, clubby tailights, clubman "S" rim as a spare, the std deluxe doors, mind you it could have just had a nasty rear ender, and they wrecked a clubby n put on the back end, and had a left over wheel?
IF you go to inspect it, have a look inside the boot, around the tailights, there shall be some stories id imagine.
-Cam :lol:
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
