https://ausmini.com/forums/
Normal or Hi-flow? need help/advice
https://ausmini.com/forums/viewtopic.php?f=2&t=15635
Author:  =twista= [ Sun Jan 29, 2006 5:16 pm ]
Post subject:  Normal or Hi-flow? need help/advice
Heya again fellas, im currently in the middle of a rebuild of my 1100 motor, and im wondering whether i should use a normal water pump or a hi-flow water pump? im really not sure what to use, what would be an advantage, or what would best suit my motor.
Much help needed.
thanks
Author:  fuzzy-hair-man [ Sun Jan 29, 2006 5:21 pm ]
I think the standard answer is a high flow pump the std pump does not move much water and the high flow pump will improve this usually idling is a problem because the pump is not going very fast and the flan is not providing much airflow. :wink:
Author:  Hanra [ Sun Jan 29, 2006 6:26 pm ]
High capacity water pump simply uses a larger impeller, check clearance of impellar to block, as it protrudes in the water jacket further than a standard pump.
Author:  =twista= [ Sun Jan 29, 2006 7:08 pm ]
thanks
