It is currently Sat Aug 02, 2025 12:22 pm
 Post subject: Numbers
PostPosted: Sun Jan 29, 2006 3:43 pm
I have found
99H834AJH013110 12G202
A/BZ2
BC&M 22G 1832
Can anyone tell me what i have to build on ?
Thanks for the help
Andrew
PostPosted: Sun Jan 29, 2006 4:40 pm
1000cc (998) Motor with 12G202 head (1100cc style) My book says this would be from a Leyland Clubman S.
Gearbox number refers to 4synchro Rod change with small dia (bearing) Idler Gear.
These 99H motors are usually strong as donkeys and make good sloggers for an 'everday mini!
:D 8) :D 8)
Sir Alec! we are not worthy!
PostPosted: Sun Jan 29, 2006 4:56 pm
Thanks for that Graham...
Im thinking about building on this??
Is it a good starting point ? or should i look for something else?
Andrew
PostPosted: Sun Jan 29, 2006 5:03 pm
Depends what you want out of it? if your just after something to get around on, they're great, realiable and economic transport. Just don't go expecting it to blow your socks off performance wise :)
PostPosted: Sun Jan 29, 2006 5:09 pm
Mini mad how about with some $$$..
could i make it more sock blowing? haha
Andrew
PostPosted: Sun Jan 29, 2006 5:14 pm
Yea, if you stroke it with a 1098 crank and put a decent cam in etc...it wont be too bad..just a little slower than a commodore..
Tell you what, if you come along to the cruise if Feb, i'll be there with my car (provided i get it re-registered and it's not apart for the build) and you can come for a ride. It's one of the most powerful small blocks on here (shut up james :lol:) ...if not mine gafmo's is pretty much the same..
PostPosted: Sun Jan 29, 2006 5:24 pm
josh you forgot to say that the most powerful small block may also be for sale soon to the highest bidder :D
1974 Moke - 998cc
PostPosted: Sun Jan 29, 2006 7:54 pm
.... or might just be getting ripped apart and built even nastier :twisted:
Watch this space.....
100@wheel is the target ....
2006 is the Timeframe
Intercooled 18PSI @ 6000 RPM is the method
998cc is the Machinery .....
J
