It is currently Sun Aug 03, 2025 12:23 am
PostPosted: Sun Jan 29, 2006 5:16 pm
Heya again fellas, im currently in the middle of a rebuild of my 1100 motor, and im wondering whether i should use a normal water pump or a hi-flow water pump? im really not sure what to use, what would be an advantage, or what would best suit my motor.
Much help needed.
thanks
Image Image
PostPosted: Sun Jan 29, 2006 5:21 pm
I think the standard answer is a high flow pump the std pump does not move much water and the high flow pump will improve this usually idling is a problem because the pump is not going very fast and the flan is not providing much airflow. :wink:
Roads need more corners
PostPosted: Sun Jan 29, 2006 6:26 pm
High capacity water pump simply uses a larger impeller, check clearance of impellar to block, as it protrudes in the water jacket further than a standard pump.
PostPosted: Sun Jan 29, 2006 7:08 pm
thanks
Image Image
