It is currently Sun Jul 20, 2025 11:10 am
PostPosted: Thu Aug 25, 2005 2:27 pm
I came across this Mini for sale the other day and I have never seen an engine like it. The oil filter screws straight into the block to the left of the didtributor where the mini engine normally has the oil pipe coming out that goes to the filter housing. The engine number starts with 10H/705EH####. Has any one got any Ideas of the engine sort ? The guy recons it is a 1071 ? I can't say anything as I have never seen one.
PostPosted: Thu Aug 25, 2005 2:29 pm
Probably Sth African. Their `1100' motors were 1071 but with a big journal crank. Filter screws direct onto block, like the last of UK ones too.
Last edited by drmini in aust on Thu Aug 25, 2005 2:30 pm, edited 1 time in total.
South African, big bore, short stroke, large journal
PostPosted: Thu Aug 25, 2005 2:37 pm
yes, like that 2000 Rover Mini at the All Brit Day. I noticed that (after gafmo pointed it out)
PostPosted: Thu Aug 25, 2005 5:06 pm
yes thats the one.
south african 1098 big bore short stroke, bullet proof motor.
we revved one out for an hour once with a brick on the accelerator pedel and guess what it ran out of petrol before it stopped the guy still drives it to this day. valve bouncing at 7000rpm.
amazing motor.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Thu Aug 25, 2005 5:37 pm
Didn't the A+ RWD engines have this???????????????????????
PostPosted: Thu Aug 25, 2005 5:42 pm
Marina 1300s etc in NZ got it I think, but we got the POS OHC motor... :lol:
PostPosted: Thu Aug 25, 2005 6:15 pm
something like this?
tho mine is a 1275
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Thu Aug 25, 2005 6:20 pm
How the hell do you filll the filter up before putting it on..I guess I just answered myown question..You dont
PostPosted: Thu Aug 25, 2005 8:18 pm
indeed.
do you normally fill an oil filter before fitting it? I don't.
 Post subject: A Series
PostPosted: Thu Aug 25, 2005 8:46 pm
Oil pressure at start up ain't an A Series forte....
thats why some people assemble their old fashioned oil filters and 2/3 fill it with fresh oil before screwing it on to the housing :wink:
PostPosted: Thu Aug 25, 2005 8:52 pm
True. :lol:
Also like many Toyotas etc it is thoughtfully designed to pi$$ oil all over the engine when you take it off... :x
PostPosted: Thu Aug 25, 2005 8:57 pm
minicranks wrote:
yes thats the one.
amazing motor.
is it the same as the first UK S motors? do they run a 1275 type (large water jacket) head? if so, I want one, make a nice little screamer...
PostPosted: Fri Aug 26, 2005 6:41 am
I have just put my belovved one up for sale for $4500. full spec motor fully rebuilt.
Not the same as an early S motor as far as i know, but yeah runs large jackets etc its a really good motor but the oil filter is the hassles as the south african ones have a 1 way drain valve in them the local ones dont, so you always get a bit of drain back in the motors, but mine has been running for 4 years over here without a hiccup.
if anyone is interested, it works out a lot cheaper than building one yuorself.
http://www.trademe.co.nz/structure/auct ... d=34286628 i think that should get you to the specs.
Ill ship anywhere if buyers cost.
 Post subject: Re: A Series
PostPosted: Fri Aug 26, 2005 11:46 am
hmmm....good tip, thanks!
