Bad Mini Day??? https://ausmini.com/forums/viewtopic.php?f=2&t=10452 |
Author: | Smokie [ Wed Aug 24, 2005 2:46 pm ] |
Post subject: | Bad Mini Day??? |
I dunno, maybe I have bitten of more that I can chew or afford with my Clubbie. Just got a quote of $1000.00 to reuphoslter the front and back seats and fit new headlining and then there will be the cost of a full paint job plus a new vinyl roof. Also when I drive the beastie I get a lot of clutch shake when moving off and have probs changing up and down through the gears so maybe a new clutch or gearbox might be needed??? Just starting to wonder if it's worth the cost and effort to fix it all up or should I sell it now before I have to spend more. Or am I just having a bad Mini day and I will get over it?? |
Author: | J_A_M [ Wed Aug 24, 2005 3:08 pm ] |
trim pricing is spot on. My trim work set me back $890, and that was front / rear seats only. |
Author: | Harley [ Wed Aug 24, 2005 3:32 pm ] |
What's the breakdown on that? Meaning how much for back seat only? |
Author: | Wolfman [ Wed Aug 24, 2005 3:33 pm ] |
You'll get over it, just go for a drive in a hilly bendy area and you'll soon know it's all worth it ![]() |
Author: | Smokie [ Wed Aug 24, 2005 3:49 pm ] |
Well Harley, all I can tell you is all the seats will cost $750.00 and the roof lining will cost around $300.00 .. Trouble with taking it for a drive Wolfman is that it sometimes wont go into gear and makes that horrible crunching sound when I try putting it in to a gear and that only upsets me more... And yep, do know the vinyl roof does cause rust on the roof as there is bit there now but I was told there is certain paint that can be sprayed on before putting the vinyl on and that should stop the vinyl from sweating. |
Author: | J_A_M [ Wed Aug 24, 2005 4:00 pm ] |
Smokie wrote: Trouble with taking it for a drive Wolfman is that it sometimes wont go into gear and makes that horrible crunching sound when I try putting it in to a gear and that only upsets me more... .
I hear you! That's what JAM was doing, and still is to some degree. |
Author: | poeee [ Wed Aug 24, 2005 4:19 pm ] |
Sounds like clutch to me. |
Author: | coops [ Wed Aug 24, 2005 4:59 pm ] |
Smokie wrote: Well Harley, all I can tell you is all the seats will cost $750.00 and the roof lining will cost around $300.00 ..
seat seems reasonable price but my roof lining only cost $130 in velour and it's perfect and beautiful ![]() |
Author: | fuzzy-hair-man [ Wed Aug 24, 2005 5:51 pm ] |
coops wrote: seat seems reasonable price but my roof lining only cost $130 in velour and it's perfect and beautiful
![]() I think this one is on the outside ![]() roof lining not hoodlining I almost assumed that.. ![]() |
Author: | Smokie [ Wed Aug 24, 2005 6:05 pm ] |
Quote: I think this one is on the outside
Ummm nope, inside one fuzzy... ![]() |
