It is currently Tue Jul 29, 2025 10:17 pm
PostPosted: Wed Aug 24, 2005 2:18 pm
In the booty haul that my inlaws got last week was this motor / box combo:
Engine #: 015/6047
Box #: 22G1832
Anyone know what these are? I tried a google and came back with nothing.
I will take pics tonight (I have to unload it from the trailer)
PostPosted: Wed Aug 24, 2005 2:39 pm
The box according to my list is a rod change, all synchro 1974 on. I don't know about the engine number, are you sure it isn't 1015/6047, that would make it an 1100 from a Leyland Mini S sedan, Leyland Mini sedan or van. As far as i can tell.
Steve.
PostPosted: Wed Aug 24, 2005 2:46 pm
aaahhhhh...it probably is 1015. I will have a closer look tonight. That checks out with the box number then.
Thanks Steve!
PostPosted: Wed Aug 24, 2005 3:16 pm
High heel ninja
1015 is a mini k/early clubman 1100 motor.
Doogie
PostPosted: Wed Aug 24, 2005 3:46 pm
Doogie
Late Mini K ? My mid 70 K has a 10Y number.
PostPosted: Wed Aug 24, 2005 4:09 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
k's were around in 71 to
makka
PostPosted: Wed Aug 24, 2005 4:11 pm
... and 69
PostPosted: Wed Aug 24, 2005 5:50 pm
:D
Sometime around 1971 BMC/Leyland in their wisdom changed the engine prefix numbers to "reduce the number of stamping operations, a simplified??? Serial Number prefix code for Australian power units is released". Quote from Clubman parts manual December 1972-PUB 1052.
It only has codes for Mini 1100, Mini 1100 Van, Mini Clubman and Clubman GT.
1100 Mini and van and 1100 Clubman codes became 10 +00 to 05 depending on model and if high or low compression ( was 10Y) and Clubman GT became 1200 (was 9FXEY). 1201 was a replacement short engine for Clubman GT.
Clubman GT cars with the non Cooper 'S' engine used 1206. (Not in parts book but from Gavin's NZ site)
Don't have any info for Mini K but the later cars would have been caught up in the number changes so 1015 could be a Mini K.
Regards
RonR
PostPosted: Wed Aug 24, 2005 10:50 pm
you've educated me again - thank you!
Users browsing this forum: Bing [Bot] and 98 guests
