It is currently Tue Aug 19, 2025 12:53 pm
PostPosted: Tue Aug 23, 2005 12:40 pm
hi all - hope you can help...
I got a non standard tacho for the clubby and now i just gotta put it in! there is 6 wires coming of it, where do they go?
im guessing there is a earth, power, illumination (which i guess goes to the park lights) i guess theres gotta be a wire to go to the ignition coil but how??
i tried to put a smiths one in my last mini and couldnt get it to work but then someone told me that i might have blown it up or some sh*t when i was trying to do it and thats why it never worked! i dont wanna make that mistake again!
Also, does it need to be calibrated or anything or will it just work when i wire it in? and one more thing... what should i set redline at???
oh if anyone has a wiring diagram for a 1978 leyland that would be handy...
Thanks, Mel
PostPosted: Tue Aug 23, 2005 12:46 pm
I only know 4 of em..
maybe the other 2 are for the shift light if u have one.
anyway,
green: - side of coil
white: backing light, hooked to power or headlights
red: power, acc, what ever
black: earth
hope that helps
PostPosted: Tue Aug 23, 2005 12:52 pm
cheers for that. I dont have a shift light so i dunno what the other 2 are for! i will chuck it in with the 4 wired up and see if it works!
Thanks
PostPosted: Tue Aug 23, 2005 1:02 pm
no worries mate, good luck
PostPosted: Tue Aug 23, 2005 2:01 pm
and there a several threads about wiring tachos already running. Grab a coffee, try a search wiring+tachos and start looking :) I know there has been a 6 wire tacho mentioned before but I dont know "which" tacho thread it was in... good luck :)
www.crazybitchracing.com
Users browsing this forum: Bing [Bot] and 385 guests
