Your shock settings are actually quite interesting from the perspective of the previous anti roll bar conversation. You can effect over or understeer with shock settings, firm reduces grip on that axle, soft increases grip. Your preferred settings seem to suggest you either prefer some understeer or something is tending your mini to oversteer which your shock settings are countering, it may be the gravel roads you mention. Either way it suggests an rear arb would take you further from the settings you seem to prefer.
_________________ --- Roads need more corners A Deluxe(CG13DE), 2 Clubbies(998 and 1275) and 2 Morris 1100Ss
