It is currently Sat Aug 09, 2025 1:57 pm
 Post subject: Sway/ anti roll bar.
PostPosted: Tue Jul 08, 2025 8:56 pm
Firstly is a sway or anti roll bar of any benefit on a road car and what is its purpose and effects.
Secondly to identify what type. An angle iron frame bolted across the rear of the rear subframe and along each side member. The bar is attached to the frame with rubher mounts with, from what I can tell are rods attached to the bar and then the bottom of the hubs somehow. I tried to take photos but I will need to hoist the rear to get a good one.
Any ideas appreciated.
Cheers Dave.
 Post subject: Re: Sway/ anti roll bar.
PostPosted: Tue Jul 08, 2025 10:08 pm
My first MK2 S had K-mac (hydrolastic) front and rear bars when I bought it in 1976, installed by previous owner (original owner). My current resto MK2 S did have holes drilled in the rear subframe for a rear bar, though not fitted. I am installing Selby dry suspension sway bars on this car, having made brackets for the rear arms per pics below. K-mac bar on original car had pressed steel brackets mounted on rear bump stop bolt, with links dropping down to bar. Use of a rear anti-roll bar increases roll stiffness, therefore helping reduce understeer apparently.
PostPosted: Tue Jul 08, 2025 10:51 pm
Dave, a “sway bar” (aka roll bar) is basically a torsion bar that transfers load diagonally across the car. Ie a rear bar transfers load (and so grip) from the outside rear wheel to the inside front wheel… which is why people usually fit a rear bar to Minis …. to load the inside front wheel to reduce understeer by increasing front end grip. Having a bar at each end just complicates things..
Most of them are round section ..like the set I bought at Selby’s Sydney MotorShow stand in ‘76 for my Golf. but there’s no law that says they have to be….
Get a case of beer and we can discuss the fine print.
Cheers, Ian
PostPosted: Wed Jul 09, 2025 11:13 am
Cheers, Ian
Thanks for the great explanation, makes it really clear. I already have the beer. ;-)
Mine looks nothing like the ones ausdino has shown. Will try for better pics.
Cheers Dave.
PostPosted: Wed Jul 09, 2025 2:53 pm
Theoretically the sway bars don’t change the way the suspension works when you’re driving straight with no load on the suspension
When you add load, like around a corner the sway bar effectively adds stiffness like you’ve got a stiffer cone/spring
With a classic mini, normally a sway bar is added to the back end, and the stiffer effective suspension reduces the rear grip, in turn reducing the amount of understeer.
PostPosted: Tue Jul 15, 2025 7:06 am
Sorry a bit late to the party, but thought i would chime in with a possible ' road version' caution.
The info above is a very good explanation of the effects -
the action of either reducing front understeer or actually increasing oversteer by letting the rear hang a bit is exacerbated in the wet.. In just about every case I know in a wet race setting - teams either loosen up the rear sway bar or disconnect it due to the much higher probability of doing a pirouette ( losing the back) There is practically zero warning . No idea of whether spirited road driving in wet conditions would trigger that scenario - but i thought it worth a shout out.
PostPosted: Tue Jul 15, 2025 7:30 pm
Pretty sure I have a set of KMAC brackets for dry suspension if anyone is interested.
PostPosted: Tue Jul 15, 2025 9:17 pm
I just reread the “Suspension” chapter of David Vizards, How To Modify Your Mini.
His recommendation is to maximise the grip of the front suspension first (you will need adjustable suspension components to do this) and if this does not reduce understeer enough, then perhaps fit a rear anti roll bar.
Regards
Phil
PostPosted: Sun Jul 20, 2025 4:57 pm
Adding my 2 cents because I've gone down the suspension rabbit hole a bit :oops:
Yes, if you consider the rear axle in isolation you lose grip, the rear arb does however contribute to limiting roll for the whole car not just the rear axle, the mini has skewed roll (rear roll centre lower than the front) which means the rear has an outsized effect on roll. Limiting this means the weight distribution can be more even at the front and you get an overall gain in grip.
I agree, it seems much more productive to add grip to the front before taking it from the rear, the mini was setup to understeer from the factory so reversing some of these seem a good place to start. Negative camber bottom arms (fixed or adjustable) and adjustable caster / tie bars, maybe lowering a bit and roll centre adjusting lower ball joints then if required start on the rear.
Absolutely this is the reason the mini and most OEMs set their cars up to understeer, the layperson will automatically react by easing off the throttle or braking which is a response for understeer that won't get you into worse trouble. Note power oversteer and oversteer are different (or so it's been explained to me) a rwd which kicks out the rear under power can still understeer at a corner.
By adding grip to the front incrementally to sort understeer you can stop once the balance is where you want it.
Other ideas to limit understeer / promote oversteer:
  • The other approach that worked for me was to add rear hydro bumpstops to a rubber cone car, I added them primarily because it made it 'feel' better coming into a corner but it also would help control roll.
  • Caster can also be used to create dynamic camber at the front, that is when you turn the wheels, which sounds useful but camber also adds steering weight and the mini doesn't have power steering...
  • The factory settings for toe on the rear favoured toe in, setting this to straight could also help limit understeer. Toe out at the rear promotes oversteer and is not recommended for a road car or most race cars AFAIK.
  • Just as negative camber (more grip) in the front promotes oversteer or less understeer, positive camber (less grip) in rear can promote oversteer.
  • Another more left field way might be to put wider 165? tyres on the front and narrower 145? on the rear. Sounds whacky but it would be a cheap experiment to see if you like more oversteer.
A question I've wondered... when you see a race mini or similar with it's rear inside wheel dangling in the air are these always cars with rear anti roll bars fitted? There's a massive amount of droop travel on a mini so I can't see them running out of droop so to my mind it has to be ARB related.
Roads need more corners
PostPosted: Mon Jul 21, 2025 7:03 am
to fuzzy
I think all of the race cars ( Group Nb and Nc) that i know of use a rear sway set up ( lots of versions)
They all can pose for a brilliant heavy braking and cornering photo with the rear inner wheel lifted.
Most of them have the front suspension pick up points raised ( allowed in regulations). This was very effective at reducing understeer in my car - but as mentioned above in conjunction with knowlege of tyres/ cambers/ toe in out, wheel weighting etc etc
PostPosted: Mon Jul 21, 2025 5:50 pm
FNQ wrote:
to fuzzy
I suspected as much.
If this is the mod I'm thinking of you mean the inner pivot(subframe) for the lower suspension arm has been raised? If so that's a roll centre adjustment, it raises the roll centre, commonly after the car has been lowered, the other way to achieve it is extended lower ball joints(which is what my mini has).
I've also raised the rear suspension roll centre to help with that skewed roll axis thing, I think the difference is worth it but it was a huge amount of work. Semi trailing arms now not trailing arms... :wink:
PostPosted: Mon Jul 21, 2025 7:59 pm
Excellent 8nfo and tech from all.
Which leads me to the question, are they of much benefit on a road car mainly used on sealed roads?
Cheers Dave.
PostPosted: Mon Jul 21, 2025 9:07 pm
It depends on how far you want to go, why you're improving it, what feel you want from the car.
My list in order for handling mods would be something like:
  • Hilos but good ones not the plain flat ones. I tried the cheap flat ones after my ripspeed ones and it was barely more than a couple of kms before I took them out.
  • Negative camber bottom arms either fixed or adjustable
  • Camber / tie bars needed anyway with camber arms
  • Rear hydro bumpstops
  • Front roll centre correction.
  • Adjustable toe and camber on the rear assuming your rear subframe is straight, if not the adjustable brackets will let you sort it out and they're pretty cheap.
BTW I run standard cones and KYB gasAdjust dampers.
The last 2 you could change in order, the car felt better turning into a fast (100km / hr) turn but it felt more composed with the roll centre correction. I've only ever had my mini on the road so I am concerned with what feels nice to drive rather than necessarily faster.
On a different but related aspect a LSD / ATB made a massive difference, but larger offset wheels outwards (negative) give torquesteer with the diff, but having felt the difference I'd avoid the large offsets in either case. I haven't had it on anything but 10s but from what I've read (vizard and calver) they are likely the best for handling.
Another thing is suggest is learn how to do your own wheel alignment then you can change it to suit your needs without paying each time, string lines etc are accurate, it's a PITA initially but once you get repeatable measurements it gets easier.
PostPosted: Tue Jul 22, 2025 10:59 am
Yes I do my own wheel alignments here on Minis and I have some basic old school gear to do it. My main Mini, a Clubman, is set up pretty much as you describe, adjustable height, camber and tie bars and standard cones. The rear though is pretty much standard apart from adj height, Konis on the rear, Spax on thee front and it handles well.
I am intrigued about hydro bump stops and I am not sure what you mean by front roll centre correction.
I am going to pull the sway bar off the van body, see what it is about and look at trying it on my main Mini to see what gives.
Thanks for the info.
Cheers Dave.
PostPosted: Tue Jul 22, 2025 11:34 am
'ausdino'
Did you add some extra bracing to your rear subframe pictured above and if so what is the benefit?
