It is currently Fri Jun 20, 2025 6:07 pm
 Post subject: Part name
PostPosted: Sun May 04, 2025 1:39 pm
Hi All. I’m chasing the name of the cover used to fill the large rear hole behind the rear seat. I’m not having much luck searching for a replacement without the correct name. All advice gratefully received.
 Post subject: Re: Part name
PostPosted: Sun May 04, 2025 2:19 pm
The original piece was part 14A4476 and made from compressed fibre board/masonite/cardboard and held in place with self tapping screws into speed clips. I can't find anywhere that sells them, so you may need to make it yourself
Some more details here:
viewtopic.php?f=2&t=90876&p=986913&hilit=14A4476#p986913
PostPosted: Sun May 04, 2025 6:20 pm
Thanks so much. I’ve kept the old one but it looks a little second hand.
