The reservoir is offset to the mounting flange LH and RH. If you have tin can ones on the car now hold it alongside with flange at the same angle and view from above.
It will be obvious which one it is.
Or measure the bore, if 0.750" it's probably a clutch MC.
if 0.700" it's a brake one.
Exceptions
850 had 0.750" brake MC
998 Cooper had 0.625" brake MC.
