What are your thoughts on painting under carriage? https://ausmini.com/forums/viewtopic.php?f=2&t=102528 |
Author: | Tim_Mini_Man [ Sat Apr 26, 2025 5:28 pm ] |
Post subject: | What are your thoughts on painting under carriage? |
Hi all, Recently I have seen some pictures of minis with the undercarriage painted the same colour as the car. What are your thoughts on this? Should or shouldn’t I do this using this product from auto barn Car Builders TXT 2K Tintable Texture Coating Kit 1L - 2KTINTKIT1L I’m planning on painting the mini Gambier Turquoise |
Author: | Tim_Mini_Man [ Sat Apr 26, 2025 6:04 pm ] |
Post subject: | Re: What are your thoughts on painting under carriage? |
And while I’m at it, any recommendations for the subframes? |
Author: | timmy201 [ Sat Apr 26, 2025 7:24 pm ] |
This video uses a similar tinted under body paint. I want to do this to my mini when I've got some time and some space to make a mess getting the old coating off https://youtu.be/44vcVEFkGHA?si=aZWweoimxjzvHyBt |
Author: | Sreedon [ Sun Apr 27, 2025 7:15 pm ] |
For subframes, suspension arms etc I’m using this stuff. It’s amazingly tough and similar to POR15 in that it’s a moisture cure coating. https://www.kbs-coatings.com.au/how-to- ... tructions/ I’ve tried rattle can epoxy paints but they all seem to scratch very easily. |
Author: | ausdino [ Mon Apr 28, 2025 12:22 am ] |
Sreedon wrote: For subframes, suspension arms etc I’m using this stuff. It’s amazingly tough and similar to POR15 in that it’s a moisture cure coating. https://www.kbs-coatings.com.au/how-to- ... tructions/ I’ve tried rattle can epoxy paints but they all seem to scratch very easily. The kBS system is very good - an excellent hard wearing finish on the clubman chassis after sandblasting. I used the KBS satin topcoat over the normal gloss finish. |
Author: | Phil 850 [ Mon Apr 28, 2025 9:24 pm ] |
I also used KBS for my Range Rover chassis and suspension. Attachment: 9CED1167-C98C-4E5D-8089-538948BDC4E8.jpeg I went through the entire three step process, Rust Blast, Aquacleen and Rust Seal. I used gloss. Phil |
Author: | MiniPete [ Tue Apr 29, 2025 8:11 am ] |
Tim_Mini_Man wrote: Hi all, Recently I have seen some pictures of minis with the undercarriage painted the same colour as the car. What are your thoughts on this? Should or shouldn’t I do this using this product from auto barn Car Builders TXT 2K Tintable Texture Coating Kit 1L - 2KTINTKIT1L I’m planning on painting the mini Gambier Turquoise That product will work fine and give a nice texture, along with a little bit of soundproofing. Obviously you need to buy the schutz gun, and take safety precautions using the product. They also do a 1k product, which is good as well, as you can use half a tin and put the left overs away for later, whereas the 2k, you need to use it all once catalysed. I am thinking of doing one of my cars using a 1k product called Voodoo Liner. |
Author: | Tim_Mini_Man [ Sun May 04, 2025 8:46 am ] |
Thanks all |
