HS2 overflow https://ausmini.com/forums/viewtopic.php?f=2&t=102440 |
Author: | whizzbang [ Wed Nov 27, 2024 10:57 pm ] |
Post subject: | HS2 overflow |
Is it possible to fit an overflow pipe to an AUD146 HS2. If so how, please? |
Author: | timmy201 [ Thu Nov 28, 2024 5:12 am ] |
Post subject: | Re: HS2 overflow |
You’ll need a different lid with an overflow port / breather vent Eg https://www.barnfindspareparts.com.au/s ... ud9203~852 https://www.barnfindspareparts.com.au/s ... id-aud9210 This is the standard type with the pin hole https://www.barnfindspareparts.com.au/s ... id-aud9203 |
Author: | Bill B [ Thu Nov 28, 2024 1:17 pm ] |
timmy201 wrote: You’ll need a different lid with an overflow port / breather vent Eg https://www.barnfindspareparts.com.au/s ... ud9203~852 https://www.barnfindspareparts.com.au/s ... id-aud9210 This is the standard type with the pin hole https://www.barnfindspareparts.com.au/s ... id-aud9203 Quick question: On the Barnfind lid, (AUD9210) is the 2nd brass vent for supplying the other carburettor in a twin set-up rather than an overflow? |
Author: | timmy201 [ Thu Nov 28, 2024 3:13 pm ] |
I couldn’t tell from the photo Bill. There seem to be many different versions, some with the second port at 90 degrees to the inlet, some at 180 degrees and the same applies to the overflow port. Some have an inlet, second carb port and also the vent https://sucarb.co.uk/float-chambers-spa ... -lids.html |
Author: | Hinesy1275 [ Fri Nov 29, 2024 7:39 am ] |
Generally the 9210 secondary pipe was an overflow - application to MGB etc |
Author: | whizzbang [ Fri Nov 29, 2024 7:09 pm ] |
My AUD146's have the small vent under the metal clip. Can this be drilled out and a small pipe fitted? |
Author: | timmy201 [ Fri Nov 29, 2024 7:21 pm ] |
It’s probably possible, but it’d get very close to the fuel inlet rubber hose. |
