It is currently Fri Jul 18, 2025 3:15 pm
PostPosted: Thu Nov 28, 2024 6:25 pm
Where would an oily residue or film be coming from on the rear drivers side swinging arm?
I hve cleaned it up to hopefully locate. There is also some on the inside of the wheel. It is not brake fluid and doesn't look like grease but it must be from the arm or the wheel bearing so must be grease.
It had spread all over the top of the arm with some in the wheel. I have checked if the arm is to blame and cannot see anything obvious. Its got me tossed.
Cheers Dave.
PostPosted: Thu Nov 28, 2024 6:41 pm
Possibly the shock absorber?
PostPosted: Thu Nov 28, 2024 8:15 pm
Thanks Tim I did not think of that. They are Koni adjustable. Are they gas or oil does anyone know
Cheers Dave.
PostPosted: Fri Nov 29, 2024 4:01 pm
All shocks have mostly oil, gas ones just use nitrogen instead of air too.
PostPosted: Fri Nov 29, 2024 7:10 pm
Thanks Doc, I realised that this morning, late night posting nd too many beers dulls the brain function.;-),
Anyhoo, the oil residue is on the back burner, the mini quit while out 9n a run today so that ne3ds fixing now.
Cheers Dave.
PostPosted: Sat Nov 30, 2024 11:33 am
I had Konis on my Fiat 124S and also Barney the pretend S, neither were 'gas' shocks.
They are good, and rebuildable too.
PostPosted: Tue Dec 03, 2024 6:57 pm
An engine oil leak will gradually work its way down to the back of the car
