It is currently Sat Jun 21, 2025 3:44 am
PostPosted: Fri Oct 04, 2024 8:25 pm
Hi all,
is it possible to swap the older square body wiper motors for the later round one?
I know the mounting bolt pattern is different, but an adapter plate could sort this.
Reason: I believe the round body motor is more powerful & durable .
So I'm guessing it comes down to sweep patterns and wiring.
Not looking to go two speed. I like to keep things simple (sarcastic LOL)
Thanks for any responses.
Pete
PostPosted: Sat Oct 05, 2024 12:00 pm
1stmotionshaft wrote:
Hi all,
Pete
For mounting of the motor you simply need to drill three new holes in the bulkhead to suit the round body mountings.For wiring, you need to wire the roundie up right.
PostPosted: Sat Oct 05, 2024 3:40 pm
Be aware the Lucas Australia round bodied wiper motor (12AUW) has regenerative braking so needs to be wired up differently to the square bodied type. You will need a different switch.
Good info here courtesy of gtogreen1969 - viewtopic.php?f=2&t=100414
PostPosted: Sat Oct 05, 2024 8:32 pm
Hi all,
Pete
The mounting of the later wiper motor just needs 3 new holes drilled.
PostPosted: Sun Oct 06, 2024 10:34 am
Excellent information, thanks everyone.
Pete
Users browsing this forum: Google [Bot] and 85 guests
