It is currently Sat Jun 21, 2025 1:07 pm
 Post subject: MK2 WIRING MADE EASY
PostPosted: Sat Aug 31, 2024 11:51 am
I think I got this picture from this site and few years ago. I would like to make this for my Mk2. It would make things easier. Just disconnect the loom and everything is made easier. What parts are required to make this type of harness in the wiring.
 Post subject: Re: MK2 WIRING MADE EASY
PostPosted: Sat Aug 31, 2024 12:34 pm
Looks like one of these
https://automotivesuperstore.com.au/deu ... z6JN4NckuY
Crimper
https://automotivesuperstore.com.au/raceworks-rwt-004
and get one of these in case you need to remove or move the pins around
https://automotivesuperstore.com.au/raceworks-rwt-030
PostPosted: Sat Aug 31, 2024 1:02 pm
That was made by Morbo, he did a number of similar sublooms like that using Deutsch type connectors
viewtopic.php?f=3&t=86822&start=885
PostPosted: Sat Aug 31, 2024 2:14 pm
andrew9 & timmy201 Brilliant. Thank you guys.
PostPosted: Sun Sep 01, 2024 11:31 am
Using Packard 56 series type connectors is another option. The Packard connectors allow for the mixing of terminal sizes but lacks weather sealing.
Too many minis
PostPosted: Tue Sep 03, 2024 3:15 pm
andrew9 wrote:
The connector linked to is the DT series. The DTM series would be more appropriate.
Too many minis
