https://ausmini.com/forums/
Front Drum Brakes Wheel Cylinders 1in vs 15/16in
https://ausmini.com/forums/viewtopic.php?f=2&t=102359
Author:  70MiniK [ Thu Jul 11, 2024 3:23 pm ]
Post subject:  Front Drum Brakes Wheel Cylinders 1in vs 15/16in
Mini K and a Mini 850 Van both with leaking mildly corroded front 1in diam wheel cylinders.
(Van was changed to twin leading shoe. Also 3/4in cylinders on the rear drums of both cars)
I am considering seal kits or replacing with new cylinders. Shopping around I notice that the 15/16" size cylinder appears to far more common, with the 1in size seemingly unavailable from many stores. Was the 1in size an Aussie only thing?
Should I stay with the 1in size or change to the more common 15/16in?
What are the pros/cons of the 1in vs 15/16" front wheel cylinder size?
Author:  68+86auto [ Thu Jul 11, 2024 9:02 pm ]
Post subject:  Re: Front Drum Brakes Wheel Cylinders 1in vs 15/16in
It seems like everyone just switches between 15/16 and 1" without an issue. You will just need to file the holes as they are in slightly different positions.
Author:  slacko [ Thu Jul 11, 2024 11:03 pm ]
PM Scotta74
He has just gone through issues with changing front wheel cylinders
Author:  70MiniK [ Fri Jul 12, 2024 9:39 pm ]
slacko wrote:
PM Scotta74
Thank you, I have PM'd Scotta_74 and will post anything learnt up here.
Author:  70MiniK [ Tue Jul 16, 2024 8:35 pm ]
No reply to my PM so I've had a look at an old PBR book.
According to this PBR drawing the 15/16" front wheel cylinder should have bolt spacing of 1.48in X 0.71in
Interestingly the 1" cylinder is not listed at all. So measuring the 1in cylinder, it looks like the H dimension is closer to 0.74in.
So fitting the 15/16" to the standard back plates will require elongation of the 1/4" bolt hole by around .030in.
Is this the only fitment issue that I need to worry about?
I presume there is no noticeable change in pedal feel and front-rear bias?
Author:  scotta_74 [ Tue Jul 16, 2024 9:40 pm ]
slacko wrote:
PM Scotta74
Just PM'd you, sorry I've been away.
