It is currently Tue Jun 24, 2025 1:11 pm
 Post subject: Anti seize
PostPosted: Sat Jul 13, 2024 9:30 pm
Hi,
Can anyone please advise on the pros and cons of copper anti seize as opposed to aluminium anti seize, and where it's appropriate to use which one on a mini.
Thanks in advance.
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
 Post subject: Re: Anti seize
PostPosted: Sat Jul 13, 2024 9:47 pm
I used copper antiseize on the LCB Y piece, after 15 years one pipe wouldn't come out it was stuck fast. They do get red hot.
I had to cut the pipe off and remake it later.
I us nickel antiseize there now. But the copper one is fine for other stuff.
PostPosted: Sat Jul 13, 2024 10:19 pm
Is nickel anti seize another option
Mk 1 Cooper S 1965
PostPosted: Sun Jul 14, 2024 7:43 am
I've not seen aluminium antiseize. Both copper and nickel ones are easy to find.
I have both, and use either generally.
PostPosted: Sun Jul 14, 2024 11:02 pm
I have used it on steel cap head screws in aluminium rivnuts.
PostPosted: Mon Jul 15, 2024 10:32 am
I've never seen aluminium antiseize either - you learn something new every day...
I've used nickel antiseize for decades in industrial applications, around the home and on my cars. It just works!
As the doc alluded to earlier, copper has a lower temperature rating. Also of note is that copper is NOT RECOMMENDED for use with stainless steel.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
Users browsing this forum: Bing [Bot] and 98 guests
