It is currently Mon Jun 23, 2025 10:05 am
 Post subject: driving flanges
PostPosted: Tue Jul 09, 2024 10:46 pm
The driving flange to diff fixing is by bolt with a rubber seal etc and not a castellated nut. Is the torque setting the same for both methods?
 Post subject: Re: driving flanges
PostPosted: Wed Jul 10, 2024 6:40 pm
The driving flange held by the castellated nut was used on early minis fitted with the rubber universal joint. The manuals quote 70 lbs/ft for this nut.
The Hardy-Spicer steel universal joint is held by the bolt and rubber seal arrangement and were fitted to automatic minis and to Cooper S after mid-1966. Torque settings for the bolt are quoted in the automatic transmission section as 40-45 lbs/ft.
I guess the torque for the nut is higher as it is a larger diameter than the bolt on the Hardy-Spicer.
PostPosted: Thu Jul 11, 2024 3:45 am
Most helpful Bill B, thank you.
