It is currently Tue Jun 24, 2025 4:16 pm
 Post subject: Filter Removal Tool
PostPosted: Sat Jun 29, 2024 2:18 pm
What do people use to remove the spin on type oil filter?
This is for the Mini Spares MSF166 filter.
Was looking at the folowing type tool, but which one do I buy?
The filter has 15 flutes, and is about 73mm in diameter.
 Post subject: Re: Filter Removal Tool
PostPosted: Sat Jun 29, 2024 3:37 pm
Google will give you more choices than you will know what to do with. Repco has one for $20, and plenty more are on offering.
PostPosted: Sat Jun 29, 2024 3:41 pm
I have bought and tried just about all the tools designed for this (and some that are not). The ones i found work best on a clubman are the multigrip version or better still the vice clamp version
https://www.google.com/aclk?sa=l&ai=DCh ... QDA&adurl=
They work realy well.
Cheers Dave.
PostPosted: Sat Jun 29, 2024 4:09 pm
My subframe is my catcher's mit.
PostPosted: Sat Jun 29, 2024 4:30 pm
I never use a tool to refit them, just tighten by hand.
Cheers Dave.
PostPosted: Sat Jun 29, 2024 8:10 pm
So has anyone had any success with this style?
Looks like you could just poke it up from underneath on a 12 inch socket extension bar.
No need to remove grill, no fighting with oil cooler or spotlights mounted in the grill.
PostPosted: Sat Jun 29, 2024 8:53 pm
I use one of these as the previous filter had been overnighted and none of my other filter wrenches would undo it, but this worked.
https://shop.snapon.com/product/Oil-Filter-Wrenches/58–110-mm-Filter-Spider-Wrench-(Blue-Point)-(silver)/OFCA1
Phil
PostPosted: Sat Jun 29, 2024 11:48 pm
It shouldn't be hard to remove. If there's enough access just stab a screwdriver (or similar) into it and turn.
Too many minis
PostPosted: Sun Jun 30, 2024 8:07 am
The screwdriver method tends to just tear the filters these days. particularly if they are tight.
Cheers Dave.
PostPosted: Sun Jun 30, 2024 10:25 am
I have one like this and it’s always been able to remove tough ones
PostPosted: Sun Jun 30, 2024 10:55 am
If you use a Ryco filter then they have the tool you show that fits their filter. It may fit other brand but I'm unsure which one's.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jun 30, 2024 3:38 pm
I use one of these because I run a Cooper S oil cooler.
https://www.ebay.com.au/itm/13507317625 ... T4QAvD_BwE
PostPosted: Sun Jun 30, 2024 3:42 pm
Thanks all for the ideas.
I am after something for easy regular use on Mini's.
I think I will go with the 3 leg style.
PostPosted: Sun Jun 30, 2024 4:54 pm
scoop is right in that the base type wrenchs come in different sizes.
Find a filter you like and buy the matching tool. They aren't expensive and are much easier to use that the various "adjustable" types (IMHO;)
Cheers, Ian
PostPosted: Tue Jul 02, 2024 2:55 pm
I use this type - the packet had a listing of what filter it suits - if I remember I'll get the number off it
It does make life easier
Users browsing this forum: Hobson and 87 guests
