Paint mixing https://ausmini.com/forums/viewtopic.php?f=2&t=102280 |
Author: | DOZ [ Tue Apr 23, 2024 4:26 pm ] |
Post subject: | Paint mixing |
Anyone know a shop that can mix off the Dulon paint code? Cheers Dan |
Author: | cgo [ Tue Apr 23, 2024 5:32 pm ] |
Post subject: | Re: Paint mixing |
I’ve had acrylic paint mixed for 2 Minis based on Dulon paint codes by John’s Paint Shed at Hemmant, Brisbane. |
Author: | DOZ [ Tue Apr 23, 2024 6:03 pm ] |
cgo wrote: I’ve had acrylic paint mixed for 2 Minis based on Dulon paint codes by John’s Paint Shed at Hemmant, Brisbane. Yep, I've tried but this code does not come up at John's unfortunately ![]() |
Author: | cgo [ Tue Apr 23, 2024 6:11 pm ] |
That’s a shame, I have also had them match paint for me based on a good quality painted part, e.g. backed of a number plate holder which hasn’t seen the Sun. |
Author: | winabbey [ Tue Apr 23, 2024 6:35 pm ] |
In case you aren't aware there's a folder of paint and trim colour documents here - viewtopic.php?f=25&t=66469 Also, here's a list of PPG current paint codes - viewtopic.php?f=25&t=98953 |
Author: | Steam [ Tue Apr 23, 2024 6:42 pm ] |
It is better to take a sample to be matched as there are so ,any variables such as tints changing and colours altering that a code paint may not match anyway. |
Author: | DOZ [ Tue Apr 23, 2024 7:59 pm ] |
cgo wrote: That’s a shame, I have also had them match paint for me based on a good quality painted part, e.g. backed of a number plate holder which hasn’t seen the Sun. Yep, John's son? (I think) said to bring in a panel to match. Unfortunately only the metal under the dash vinyl is the original colour and I cant remove it from the car (Its been painted white). I just saw winnabeys post, I wish I had have seen that before - hopefully I will be able to match from that. |
Author: | DOZ [ Tue Apr 23, 2024 8:00 pm ] |
winabbey wrote: In case you aren't aware there's a folder of paint and trim colour documents here - viewtopic.php?f=25&t=66469 Also, here's a list of PPG current paint codes - viewtopic.php?f=25&t=98953 I'll try the PPG codes - thank you! |
Author: | DOZ [ Tue Apr 23, 2024 8:02 pm ] |
Steam wrote: It is better to take a sample to be matched as there are so ,any variables such as tints changing and colours altering that a code paint may not match anyway. Yep, still trying to find a photo of a Mini in Shale Green. Unfortunately for me only the metal under the dash vinyl is the original colour and I cant remove it from the car (Its been painted white). Cheers Dan |
Author: | 68+86auto [ Tue Apr 23, 2024 8:05 pm ] |
I use Harts Industrial Paints Geebung. They haven't yet failed to find a mini colour unlike who I tried previously. Johns paint shed uses the same paint system last I knew (Concept) so should have the same database. It might be under BMC or Leyland for example not Morris. |
Author: | DOZ [ Tue Apr 23, 2024 8:47 pm ] |
68+86auto wrote: I use Harts Industrial Paints Geebung. They haven't yet failed to find a mini colour unlike who I tried previously. Johns paint shed uses the same paint system last I knew (Concept) so should have the same database. It might be under BMC or Leyland for example not Morris. Thanks. I'll see how I go with the PPG code |
