reversing lights https://ausmini.com/forums/viewtopic.php?f=2&t=102238 |
Author: | whizzbang [ Fri Mar 08, 2024 10:07 pm ] |
Post subject: | reversing lights |
Where would be the most common place to mount reversing light/lights on Mk1 cooper S? Please. |
Author: | gtogreen1969 [ Fri Mar 08, 2024 10:52 pm ] |
Post subject: | Re: reversing lights |
You could do what the police cars had. The single indicator bulb holder was swapped out for a twin filament. Attachment: AL136 with Rare Spares bulb holder for reverse lamp.jpg Some info here - viewtopic.php?f=2&t=98725&p=1046729&hilit=rare+spares+al136#p1046729 Do you have the switch on the front of the gearbox as well? Attachment: 22G333 and reverse switch.png
Author: | whizzbang [ Sat Mar 09, 2024 12:12 am ] |
But you would have amber reversing lights, no? |
Author: | gtogreen1969 [ Sat Mar 09, 2024 1:05 am ] |
whizzbang wrote: But you would have amber reversing lights, no? Correct. They were only to warn other motorists that you were reversing. If you want something to light up the night then you would be better going for something else like this surface mount through the boot. Attachment: Surface mount reversing lamp.jpg Or a smaller one under the bumper Attachment: Small reversing lamp under bumper.jpg
Author: | Bill B [ Sat Mar 09, 2024 8:50 am ] |
Ditto for under the bumper. Attachment: Reversing light mounting.jpg
Author: | 1071 S [ Sat Mar 09, 2024 6:46 pm ] |
Well they were/are aftermarket item so there is no correct answer.. However, back in the 60s (esp in the UK) no serious S was without a large Lucas spot mounted to the right of the number plate (see the red car)..... (necessary for reversing rapidly out of the drive when an irate father appeared at the front door ![]() Today, a small QH reversing light under the rear bumper (see the green cars) is a practical solution that is very effective and much easier to remove than a hole in the boot should you decide not to butcher your original boot lid.... Cheers, Ian (and much cheaper at your local Supercrap than the "proper" item...) |
Author: | winabbey [ Sat Mar 09, 2024 7:51 pm ] |
The type shown above under the rear bumper on the driver's side is a BMC Accessory, the lamp itself being Hella. Attachment: Accessory Catalogue L1 Reissue 3_2.jpg Attachment: Accessory Catalogue L1A Reissue 3_2 reversing light.jpg Attachment: Accessory Catalogue L1B Reversing Light.jpg
Author: | whizzbang [ Sun Mar 10, 2024 3:27 am ] |
Thanks everyone for your replies. Most useful. |
